Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have a great white 67 lb thrust trolling motor . I can run it at 1/2 to 3/4 power and it will run for a while but when you go to full power it will shut off and you have wait a while before it kicks back on.
Sounds like it's heating up. Check your wire size. For 24 volt: 6 guage wire is reccommended - that's pretty heavy. Also check the wiring of your batteries. It's easy to get mixed up if you have 24 or 36 volt system. One more thing...check the fuse size to make sure that is correct. Hope this helps. Brian
Posted on May 02, 2009
  • jim bailey Oct 16, 2011
    I have a brute hyper 67 gator back motor guide trolling motor 12/24 volt, the problem is I don't have 24 volt's on any speed. It runs the same on 24 volts as it does on 12 volts No high speed ,have fully charged batteries and also have switched the four cables(two + two -) around does not make any difference in speed.It will run on all five speeds but no difference in 12 volt or 24 volt
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
I have a motor guide great white saltwater series 109 lb thrust 36 v trolling motor. I hooked the 3 batteries up right but it isn't running right, it's very slow. What do I do with the grey wire which has...
running to slow indicates voltage too low
you will have 3 X 12 volt batteries connected in series ( positive to negative to positive to negative with positive to motor The first battery negative connected to the ground on the motor
the multicore wire cable is for 12 volt draws as in fish finder, light etc and can be connected across any single battery terminals
They could also be for a foot controlled pedal that is forward and reverse operation
that will be explained in the user manual
Dec 06, 2017 | Car Audio & Video
How should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
Apr 17, 2012 | Minn Kota Endura 30 Freshwater Transom...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide brute 567, 67 lb. thrust
you will probably find it is either a switch problem or your wiring this is a twist handle?
Sep 29, 2008 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
1,039 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
