Question about Acer Aspire One AO751h-1401 11.6-Inch White Netbook - 8 Hour Battery Life (LUS780Y020)
Touch screen ao751h - Acer Aspire One AO751h-1401 11.6-Inch White Netbook - 8 Hour Battery Life (LUS780Y020)
Inserire Password Primario HDD Master Utente ao751h-52bk
The password MUST be entered. There is no wy to recover it!
Jul 03, 2014 | Acer Computers & Internet
Does ACER ASPIRE One 11.6" have camera ?
Yes'
General Brand Acer Series Aspire One Model AO751h-1401 Part# LU.S780Y.002 Operating System OS Provided Windows Vista Home Basic Processor CPU Type Intel Atom CPU Speed Z520 CPU L2 Cache 512KB Chipset Chipset Intel SCH US15W Display Screen Size 11.6" Widescreen Display Yes Display Type WXGA Max Resolution 1366 x 768 Display Feature LED backlight & Acer CrystalBrite Technology Graphics Graphics Processor Intel GMA 500 Video Memory Shared system memory 2GB Hard Drive HDD 250GB Hard Drive RPM 5400 RPM Hard Drive Interface SATA Netbook Camera Camera Type Acer Crystal Eye webcam Communications LAN 10/100Mbps WLAN 802.11b/g Wireless LAN Expansion / Connectivity USB 3 x USB 2.0 Video Ports 1 x VGA Audio Ports 1 x Headphone/Speaker/Line-Out Jack 1 x Microphone-in Jack Audio High-Definition Audio Support Speaker Built-in stereo speakers Input Device Touchpad Multi-gesture Touchpad (Circular-motion scrolling, pinch-action zoom, page flip) Keyboard Standard Card Reader Battery 3-cell Li-ion Battery (2200 mAh) Battery Life Up to 4-hours Manufacturer Warranty Labor 1 year limited Parts 1 year limited
Oct 14, 2011 | Acer Aspire One AO751h-1401 11.6-Inch...
AO751H was recently upgraded to Win 7 Ultimate and ran perfectly for quite a while. All of a sudden and out of the blue, the Webcam failed to operate. There is no indication in Device Manager to suggest...
Hi:
it is good pratice to first make sure your computers camera driver is compatible with windows 7, also check the computers manufacture for windows 7 update drivers for your camera.
May 22, 2011 | Acer AO751h-1279 Z520 Netbook
Needs to recover bios in Acer AO751h-1279 laptop
You can try BIOS update, please be careful with the BIOS recovery or update it can cause major problem with your system. Here's the link for the latest BIOS update you can try this:
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3212_A_A.zip?acerid=634049239663276461&Step1=NETBOOK&Step2=ASPIRE%20ONE&Step3=AO751H&OS=ALL&LC=en&BC=ACER&SC=PA_7
Apr 10, 2011 | Acer AO751h-1279 Z520 Netbook
I have an acer aspire ao751h, one day i dropped it and since then when i touched or pressed the upper right corner of the frame the screen would go off, but then i would close the lid and then open it and...
Possibly a replacement ballast unit will fix it or even just a plug hanging partially out could cause that, considering that it has been dropped.
Jan 10, 2011 | Computers & Internet
Acer netbook AO751h screen does not work, external monitor works fine.
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Sep 20, 2010 | Computers & Internet
AO751h my netbook acer audio does not work. when
Check Whether the driver for audio device is installed properly. try re-installing the audio drives and check for the problem.
Jun 30, 2010 | Acer Aspire One AO751h-1153 (LU.S820B.101)...
My Acer aspire one AO751h keeps freezing up is there any solution p.s. My os is Vista home basic k
This is a known issue in Acer aspire one A0751h model laptops. Its because of faulty motherboard, ram and cooling system. Only way to get this fixed is through Acer service center. They'll replace the faulty hardware with new one. Try with the service center if your laptop is under warranty.
Mar 11, 2010 | Acer Aspire One AO751h-1153 (LU.S820B.101)...
No drivers
You can download your driver from the link below
http://support.acer-euro.com/drivers/downloads_gd.html
How to reach your netbook driver page
Select Product Family : Netbook
Select Product Line : Aspire one
Select Product Model : A0751h
Now the drivers will be displayed below
Just click the download button, download will start automatically
Rate this Solution.
Jan 09, 2010 | Acer AO751h-1545 Netbook
Acer Aspire One AO751h-1401 11.6-Inch White Netbook - 8 Hour Battery Life (LUS780Y020) Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
