I need to change the printer margins
I need top change the print margins for a kyocera fs-3920dn. Our prints keep going on to a second page.
    President:
  • 1,996 Answers
Open the original document and use page setup and print preview (from the File menu) to modify the text until it fits on the page.
Otherwise, you may access the printer properties and preferences from the control panel, printers and faxes...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 24, 2009
My Kyocera fs-1118MFP is cutting off top margin of all documentscopy or print. How do I fix, plz help.
I don't know that machine but generically, the description suggests a faulty drum or fuser unit...
How many prints or copies since either or both were changed, please?
Sep 02, 2016 | Kyocera FS-1118MFP Laser Printer
Tip
Top margin, header page, the print is changed (lowered).
If you print and the top margin is altered (low), look at the figure below.
excuse my English.
on Oct 25, 2013 | Kyocera Mita FS-1030D Laser Printer
Kyocera fs 3920 dn printer ripping paper when it prints
Hi, dear; it have to be something stuck in the paper path, do following way; make a copy after 2 second stop the machine,pull out the paper,see there have been rip on the corner, if yes check that area, if not do next copy after run for 4 second , stop the machine, pull out the paper check it again until you found out the rip happen, the paper chip should be there. good luck
Aug 31, 2012 | Kyocera 1102J12US0 Model FS-3920DN Small...
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Kyocera fs-3830 cutting off print on top of page
check the margin settings and outline settings because minor things worries us too much
May 01, 2009 | Kyocera Mita FS-3830N Laser Printer
Kyocera Mita FS 1010 every few days it prints out all the pages
Format the harddrive, or go to the properties and change the setting that says leave copy on the harddrive, if all this not working try to initialize the memory and you will be fine.
double check on the driver properties check if it says direct printing or it keeps any copy on the machine.
Regards
Feb 13, 2009 | Kyocera Mita FS 1010 Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
405 people viewed this question
jasbo
jasbo
