Question about JVC RX-6008V Receiver
NAD 7100 How to turn off low level without a remote
My NAD 7100 receiver works flawlessly EXCEPT the low level function kicks in automatically when it starts up and cannot be turned off with the panel switch and I've lost the remote. Is a bad panel switch too easy to hope for or is there a way to reset so it does not come on?
  • gresiczkip Feb 08, 2008
    My NAD 7000 presents the same: low level option kicks in when the rig turnes on. (in my case I can defeat it with the dedicated panel button). Is this a normal operation with NAD? Could anybody give me a hint? How to modify the circuitry, if necessary? How to get a schematic diagram of the NAD 7000 - NAD 7100? Thanks!
You can ONLY defeat this feature by modifying the circuit on the mother board. The remote availability has nothing to do with this feature on power on
Posted on Nov 04, 2007
    New Friend:
I have a Monitor series 1600 preamp with the same issue - best bet is to get a Logitech Harmony remote and use that to switch the low level button.
Posted on Oct 11, 2016
**** FIXYA ITS THE WORST FUKIN SITE EVER IT HAS 10 MILLION MOTHER FUKIN QUESTIONS AND NO FUKIN ANSWERS
Posted on Sep 11, 2008
SOURCE:
I have a Nad T760 receiver/amp (not sure what the difference is). The remote cannot function. Is there a universal remote that I can buy? As this is quite an old piece of kit not sure if there is a
some remotes can be programmed by entering a manufacturers code using the numeric keys. i use a Sony RM-VLZ620 remote. it lists NAD as a supported receiver.
P.S. - a receiver is an amplifier with a built in radio tuner.
Nov 15, 2014 | NAD T760
I have an HTR-2 NAD remote. All the buttons except for the ON button are working. is there anyway to fix this?
Remote controls have an operating code which entered right will cause all functions to work. However if you were given the wrong remote or it doesn't have the right code, certain buttons will not work.
Check that the appliance it operates is the right model for the remote. Some remotes will allow reprograming others are fixed. If you can reprogram it will be just a question of finding out which code the amp uses and entering that. You can search online for the codes for your model.
It's not uncommon for the wrong remote to be sent out when first sold. Some people don't know it's wrong as the remote works nearly all the functions, just not all.
Aug 02, 2014 | NAD Audio Players & Recorders
NAD T754
Sometimes manufacturers change codes from time to time and functions that the remote controlled yeasterday can't be controlled today. You might be able to get some functionality out of another universal remote with a more extensive library of codes available. I understand your frustration - I have a bunch of useless remotes as proof.
Dec 10, 2013 | Audio Players & Recorders
Re EQ function without remote controller
Purchase a customizable universal remote or a Logitech Harmony remote.
Nov 16, 2013 | Onkyo TX-DS575 Receiver
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
Volume / audio control knob
Hi, did you ever get this fixed, if so for how much and where. I have the same problem with my knob, it does not control the volume level but you can still access the other functions that require you to push the knob, like a button. My remote battery is dead so I have not being able to test it, it's just the knob no longer controls the volume.
Dec 01, 2011 | Audiovox MP6312I
I have an old Technics SA-GX300 receiver that works fine except that the screen indicates that muting is on (still produces volume but at much lower levels). I lost the remote to the receiver. Is there...
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Jul 08, 2011 | Technics SA-DX850 Receiver
NAD tuner
Depending on your audio power needs, any will work except receivers that already have integrated tuners.
Apr 21, 2008 | NAD C425 Am Tuner Tuner
Nad 712 output issues - Mute flashing
The only thing I can tell you for sure is that the mute indicator always flashes (very dimly) when the receiver is off.  I have no idea why, but mine has always done this.
Jan 23, 2007 | NAD 712
Remote control not working
This was fixed by myself, the IR receiver was dead, replaced with a good one, working fine now.
Jan 18, 2007 | NAD T752 Receiver
JVC RX-6008V Receiver Logo
827 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
