Question about Health & Beauty
Printer problem - Health & Beauty
Printing will not align
Reinsert printer head
Problems with the printer head of printers might be because the printer head is not secure in its position. The problem would cause the printer head to wobble and produce bad prints. All printer users having problems with printer head are advised to check the seating or the printer head, remove it and then reinsert the printer head if it is not found properly seated.
Clean printer head:
As your printer is used, the printer head might get dust or dirt settlement from the paper being fed into the printer. Dirt settlement would cause printer to produce very poor print quality and such issues can be resolved by carefully removing the printer head and cleaning it with a printer head cleaning solution. However, care must be taken when cleaning the printer head and replacing it back as any damage to the printer head during the cleaning process would affect the functioning of the printer. Brother Printer Support
Oct 16, 2012 | Brother Ink for Mfc-885cw, Lc-1000
Tip
Setting up a Shared Network Printer
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer.
You need to install the printer driver on the computer and configure it as a Shared printer.
The other computers on the network need to add this printer to their computer.
Follow these steps to set-up a shared network printer :-
1. Connect the printer to the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, then if you wish you can change the Share name, then click OK
3. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
Follow these steps to configure the computers on your network :-
1. Open Printers and Faxes – click Add a printer – Next – select A network printer, or a printer attached to another computer - Next.
2. Select Browser for a printer – Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer – Next
4. Select Yes for - Use this printer as the default printer – Next – Finish
5. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
on Dec 19, 2009 | Office Equipment & Supplies
How to install network printer
Go to "Start" on any computer on your network.
Choose "Add a network, wireless or Bluetooth printer."
Choose your Canon printer from the list of available printers.
Select "Install Driver" if prompted.
(OR)
If you have any issue while installing Call on Printer Tech Help Support Toll-Free number 1-855-887-0097.
Sep 27, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
Health & Beauty Logo
468 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
