Question about Maytag Neptune FAV6800AW Top Load Washer
Washer stops at 23 minutes every time - Maytag Neptune FAV6800AW Top Load Washer
    Master:
  • 492 Answers
Could be a stuck timer.
Posted on Oct 16, 2013
Is there a filter on Samsung washer model WF337AAL/XAA
should b were the pump connects to or up inside the hose from mech to pump
Feb 19, 2015 | Samsung Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
GE High Efficiency washer model WPRE6150KWT--there appears to be a problem with the timer. A 47-minute load was still running after 80 minutes and the timer displayed 23 minutes left in the cycle. I've...
I would check screens on valve and hoses to be sure they are not stopped up. Also an unbalanced load can cause that if it's a top loader. Suspension rods would be the problem in that case.
Oct 11, 2017 | GE Profile WPRE6150KWT Colossal Capacity...
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Error code F1 on Kenmore Elite "Oasis" clothes washer
Instructions Press "Stop" to clear the current cycle on the washer.
  1. 2
    Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
  2. 3
    Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
  3. 4
    Select the desired wash cycle and press "Start."
Dec 12, 2010 | Washing Machines
Our washer gets to about 23 minutes left and it comes up with LD. What does that mean?
ld is long drain time. Maybe you have something in the drain pump or stuck in the drain.
Nov 12, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service
Jul 18, 2008 | Whirlpool Washing Machines
Clothes washer
I could not find a definite answer for you, but I know that the wash tub holds roughly 35 gallons on a full load. You can calculate the time it takes the washer to completely empty a full load to see how long it takes. If it takes 1 minute for the wash tub to empty on a full load, then you know the GPM for the drain pump is about 35 gallons per minute. If it takes a minute and a half, the rate is about 23 gallons per minute. If it takes 2 minutes, then the rate drops to about 17.5 gallons per minute. Get the idea? I hope this gives you the information you were looking for. Let me know if you have any further questions.
Feb 20, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
