Question about Refrigerators
My electrolux freezer temp is high won't come down all my food is melting help me just got a new panel today and the alarm us going off
    New Friend:
  • 45 Answers
Thermostat control problems or low on 134A refrigerant. Try cleaning the coil that gets hot on lthe underneith or back of machine ( Condensor)
Posted on Oct 16, 2013
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
Techsim
  • 59 Answers
SOURCE: Freezer losing temp... intermittent buzzing sound
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Posted on Nov 02, 2008
  • 163 Answers
SOURCE: We bought a new GE bottom freezer refridgator Sat
if not getting down to temp. it wont make ice.your ref. should be working by now.you need to call where you bought it and they will have some one come out.
Posted on Mar 11, 2009
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
  • 56 Answers
SOURCE: GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Posted on Jun 30, 2009
My high temp alarm has been on all day
the warming up will be because the unit is not operational and the door hasn't been opened
call a service technician and check for a failed start/run capacitor for the compressor
the high temp alarm indicates that the food is in danger of spoiling
Sep 06, 2015 | Frigidaire White Frost Free Upright...
Whirlpool High Temperature Alarm Keeps Blinking
New Refrigerator / Freezer usually takes up to 12 hours to get the food down to temp and the inside air temps to stabilize...
Now, try explaining that to a BSN who is required to take hourly temp readings on a refrigerator and just loaded it half full of warm soft drinks and is opening and closing the door repeatedly retrieving supplies.
You lower the temp to "suit" (shut 'er up) and tomorrow they're calling you back because it's too cold...
Apr 13, 2014 | Whirlpool Refrigerators
My elecrtolux freezer alarm going if saying freezer temp to high all my food is melting help
try cleaning the condensor (the tube/coil. that gets hot. Under or back of the machine is a fan running underneith ? if so make sure the compressor is also running. if it is not it may need a starting capacitor if it has one.
Oct 16, 2013 | Freezers
Electrolux EW26SS65GS0 Refrigerator. Temps going up. Red High temp alert and blue adjusting temp indicator lit. Suggestions?
Same problem for past month, tried replacing motherboard and today still showing Red High and adjusting....$500 so far and three service calls...what to do...food thrown out and good thing my garage is cool to store some stuff.....
Dec 18, 2010 | Electrolux Refrigerators
High temp 20-29 F Frequent high temp alarms
check condensor fan if it has one. if not unit may have sprung a leak some where
Apr 10, 2010 | Freezers
Mr.
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
Oct 03, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
FLASHING LIGHTS ON REFRIGERATORS
the reason for the blinkin light is to let you know that the freezer has detected higher than normal temps, did you expierence and food loss??? good indicator is ice cream ( it would look as if it has melted and refroze) generally you can reset the "alarm" by holdin down for 3 sec, and if it happens again soon after reseting id would imagine you are experiencing a problem.not dangerous, more for your information.
Oct 19, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
