Question about Panasonic SC-AK22 CD Shelf System
Sc-ak22 saying no disc error - Panasonic SC-AK22 CD Shelf System
  • Rajendran S
    Rajendran S Oct 17, 2013
    my sc-ak22 showing no disc when am inserrting on disc in tray..i can also see cd is not spinning... can anybody help this issue
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
I need a owners manual
You may download a copy of the manual here.
Feb 19, 2013 | Panasonic SC-AK22 CD Shelf System
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*DVD-audio
*PAL system discs
*DVD-ROM
*DVD-R
*DVD-RAM
*+RW
8DIVX Video Disc
*CD-ROM
*VSD
*CDV
*CD-G
*CVD
*SACD
*SVCD
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
MY CAMERCORDER KEEPS SAYING DISC ERROR WHEN THERE IS VIDEOS ON THE DISC HOW DO I FIX IT
Disc Error: File system does not match to the disc.
1) Disc is formatted in the PC. 2) Reformat the disc for –RW/+RW. 3) There should be no scratches on the surface of the disc. 4) Finally if dont. Take it to service.
Apr 20, 2010 | Samsung SC-DX103 DVD Camcorder
How to program out of sleep mode
no trabaja la bandeja de cd un diagrama de SA-AK22 nececito
Jun 04, 2008 | Panasonic SC-AK24 CD Shelf System
My digital cam keeps saying disc error or no disc tryed cleaning disc no good steve
Maybe the disc has some scratches or maybe there is some compatibility issues.
May 14, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Write error
I think i just figured it out. Somewhere else on the web clued me in that the disc got messed up (don't know how). I put in a new disc and it works. Other disc still doesn't though.
Nov 04, 2007 | Samsung SC-DC164 DVD Camcorder
Write error
I had the same problem. Called Samsung, they told me not to use DVD+R DL discs (despite their presence in the compatibility table in the manual). They also said DVD+R discs don't need finalizing, which contradicts the manual. I can't get them to play in my PC. For the first two discs I tried, it seemed to get write errors halfway through the disc, as if it had trouble with the second layer. I didn't record long enough on the third to find out. The camcorder still shows video on the third disc, but I can't finalize it and it won't play on my PC. Glad I'm only borrowing this camera. Won't buy a Samsung, and probably won't buy a DVD cam.
Aug 01, 2007 | Samsung SC-DC164 DVD Camcorder
Video not found after finalizing disc on Samsung SC-DC164 DVD Camcorder
Put it back in the Camera and see if it tells you the disc is finalized when it tries to format the disc. If it does then you know for sure it is finalized..
Dec 21, 2006 | Samsung SC-DC164 DVD Camcorder
Panasonic SC-AK22 CD Shelf System Logo
41 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
