Question about Activision Guitar Hero World Tour Guitar Bundle - Wii Game, Wireless Guitar for Nintendo Wii
Yellow pad on drums does not want to work this is the second time
Yellow pad on the drums doesen't want to work this is the second time it happens
  • 51 Answers
If the drumset for the Wii is similar to the drumset for the Xbox 360, then there will be a small cord connecting into the orange and yellow pads. Make sure these are plugged in all the way and are not being pulled at. It could also be that the cord could have been damaged. If that has happened, the only solution I know of is to buy a new set of drums.
Posted on Apr 30, 2009
I have rex rotary mpc 3500 copier printer scaner and copier are working properly but touch pad screen is not working i can not select paper size or zoom or any other option pl help me is there any reset or...
Hello!
You can try to adjust your touch panel.
Try this:
Press yellow key.
Press 1993 on the key pad.
Press 5 times the red key (on the fifth time keep pressing the red key for 3 seconds).
If you follow this steps it will open a menu and you will see the option to adjust the touch panel. Press that option and follow the instructions.
If this happened again you will need to change the touch panel. For that i advise you to call a tech.
Hope this helps you.
See you!
Aug 12, 2011 | Ricoh Office Equipment & Supplies
The red drum pad is not working on my wii rockband
Make sure the batteries are fresh, if yes then the sensor in the pad is broken which can happen due to the nature of the controller (you hit it with a stick) Unless you feel comfortable taking the unit apart it is time for a new drumpad set.
Feb 27, 2011 | Video Game Consoles & Games
Yellow drum pad stopped working, only had these for 5 months=(
You need to replace the piezo sensor, you can get them at radio shack really cheap. $2. The same thing happen to me, I pulled the drum pad off and the sensor was totally cracked, I guess from hitting it too hard. Just unsolder old ones and solder new one on.
Aug 21, 2009 | Nintendo Rock Band for Wii
Where can i buy a new circuit board for xbox world tour orange cymbal? preferably in sydney australia
If you’re having problems with one of your cymbals not responding to your drumstick hits then you are not alone, this is a common occurrence because as anyone who has ever played this game and gotten hooked on it you can get pretty amped up during extreme guitar and drum passages. Unfortunately for the drummer when you get amped up you start pounding your drum pads harder and harder and sooner or later there is going to be a malfunction. You can go about the repairs a couple of different ways but I’ll address your question and the not getting your hands dirty solution which is a simple replacement. Because this is such a standard and common problem with The World Tour Drum Kit (One or Both Cymbals not responding to Drum Hits) a simple Google or Ebay search with the Ebay of your Country such as Ebay Australia will bring back page after page of replacement cymbals orange and yellow. Both of the cymbals are exactly the same, what designates it either the Orange or Yellow pad is what plug you plug into it, if the left Cymbal plug is plugged in then it registers as an Orange pad the right plug Vice Versa. Each pad has a removable Orange or Yellow colored washer that designates it but this has no bearing because the right or left hand side plug designates the color, simply swap one color washer for another if the need be.
Fix number two and the one I suggest is a repair of your original. The reason I suggest repairing the unit is because, one it’s a very easy simple repair if you have just the very basic of solder skills and two, if you purchase a replacement and get crazy again while rocking out your going to damage the new one just like the old one and then your back at square one. The cymbal uses a very simple design to register drum hits; it uses an almost indestructible switch called a piezoelectric, this switch registers pressure as a reason to close its normally open switch. The piezoelectric is attached to the bottom side of your cymbal pad and when you hit the top side of it with the stick viola~ pressure from the stick is applied to the pad and thus to the piezoelectric stuck to the bottom of the pad which tells the switch to close and complete a circuit which when completed sends a signal to the drum controller brain which then tells the Xbox 360 “Hey 360, my guy just hit the yellow cymbal pad so get busy and register a yellow cymbal hit”. As I mentioned earlier the piezoelectric switch is basically indestructible so that is not the problem and if it is it would be the first I’ve heard of, the problem 99.9% of the time is that the piezoelectric has a bad solder connection from one of the two wires attached to it or the other end of the wires that are attached to a mini board. Simple fix is just re-solder the 4 solder joints (Two sides of two wires = 4 solder joints) one at a time so you make sure you have the right color wire attached to the right connection. For the piezoelectric side you’re going to need at least a 40 Watt solder iron because you need to heat up the metal piezoelectric switch itself so as not to produce a cold/defective solder joint. The other problem is even simpler to fix, the glue they used to attach the piezoelectric to the bottom of the drum pad is loose so it doesn’t register the drum hits properly. Simply remove all of their garbage glue from their crappy workmanship and use standard hot glue and gut to re-attach making sure you do not get any glue on the underside if the switch which should be mounted completely flush with the drum pad. I’m not going to give a step by step for these fixes because its already been done a hundred times but here is a link to a great video step by step that will walk you through. http://www.youtube.com/watch?v=-2QhEVER3ag if link does not work simply cut and paste this URL into your web browser.
Aug 06, 2009 | Microsoft Video Game Consoles & Games
World tour drum pad won't respong on old ps2 console
Hi-
You can repair your drums actually for pretty reasonable!
Here is a link to a video on how to repair the drums yourself,
you'll have to purchase the cable yourself, but you can find one if you search eBay for "guitar hero drum cable"
I hope this helps!
Jul 12, 2009 | Sony PlayStation 2 (PS2) Console
Drum set for xbox 360 rock band 2
to sync: hit the sync button on the drum set and the xbox at the same time, you may have to hold the one on the set.
other problem: make sure you have good batteries in it, make sure the set is synced with the television, go into the freeplay mode under the drum trainer and do a drum roll on your yellow pad- if it skips some notes you either have to deal with the bad pads or you can send it in or get a new set all in all
Mar 16, 2009 | MTV Games Rock Band Bundle for Xbox 360
Yellow drum pad just stopped working
START WITH CHECKING THE 2 WIRES INSIDE THE SET HOUSING UNDER WHERE THE YELLOW PAD ATTACHES. 1 WIRE PROBABLY NEEDS TO BE REATTATCHED WITH SOLDER.
Jan 29, 2009 | Nintendo Rock Band for Wii
Rock band for WII, blue drum pad stopped working
CHECK INSIDE DRUMSET HOUSING UNDER WHERE THE BLUE PAD ATTATCHES. THERE SHOULD BE 2 WIRES CONNECTED WITH SOLDER. IF 1 OR BOTH HAVE COME OFF THEY WILL NEED TO BE REATTATCHED WITH SOLDER.
Jan 17, 2009 | Nintendo Rock Band for Wii
IBM Thinkpad T20
try to check your settings on the display properties ->screen saver->monitor power. make sure the power is turn off never.
Jun 30, 2008 | IBM ThinkPad T20 2647 Notebook
Activision Guitar Hero World Tour Guitar Bundle - Wii Game, Wireless Guitar for Nintendo Wii Logo
277 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
