Question about Dmm Vacuum and Fuel Pump Tester Kit
1996 dodge 1500 starts then stalls, fuel filter is dry and dont hear the pump kicking on, is there another way i can test the fuel pump before replacing it
  • 115 Answers
You should hear pump running when yopu turn key on. it pumps up to pressure then shuts off. if you can get ear close to pump, have some one turn key on but not start, you should hear it run
Posted on Jul 08, 2009
  • shadron2 Jul 08, 2009
    you should hear pump running when yopu turn key on. it pumps up to pressure then shuts off. if you can get ear close to pump, have some one turn key on but not start, you should hear it run
How do i check fuel pressure on my 96 dodge ram
one way to tell if your engine is getting fuel is to turn the key but dont start it you should hear a buzz which indicates your engine is getting fuel if you dont hear the buzz you need new fuel pump. if you hear the buzz before it starts and are going only 25 check your transmission fluid make sure its not low and if its dirty change it asap it could fix your issue there, i could be wrong also but if you dont hear a buzz before you start your going to need new fuel pump and if youre doing this might as well change your fuel filter to. if it has to much dirt and is dirty you can lose pressure and your engine will run real lean.
Feb 28, 2016 | 1996 Ram 1500
Truck starts and stalls
CHECK FUEL PRESSURE,IF IT TURNS ON FOR A FEW SECONDS AND DIES,COULD BE FUEL FILTER OR PRESSURE,EVEN IF YOU HEAR PUMP KICK IN, MIGHT NOT BE SUPPLYING ENOUGH PRESSURE ,,GOOD LUCK,HOPE THIS HELPS,,
Mar 17, 2014 | 1999 Chevrolet Silverado 1500
2001 Dodge 1500 4x2 stalls when gas pedal is depressed
run fault codes to check for faulty accelerator position sensor. Have a fuel pressure test done on the manifold to check for fuel pump/ filter/ fuel regulator problems.
Oct 25, 2013 | 2005 Dodge Ram 1500
Key in ignition to on. Gauges fuel and temperature don't respond. All other electrical accessories do. Lights OK. Motor starts and stalls Vehicle is a 1996 Dodge Gran Caravan 3.8
CHECK THE DASH FUSE.IF ALL IS GOOD.YOU GOT A LOOSE GROUND WIRE OR A FAULTY DASH.BUT YOUR CAR STALLING COULD BE FUEL PROBLEMS.CHANGE FUEL FILTER AND CHECK FUEL PRESSURE.IT SHOULD BE 49 PSI.MAKE SURE YOU HEAR FUEL PUMP RUNNING WHEN YOU TURN ON IGNITION SWITCH.IF NOT.CHECK FUSE AND RELAY.IF THEY BOTH ARE OK.FUEL PUMP IS FAULTY.
Aug 25, 2009 | Dodge Grand Caravan Cars & Trucks
1996 camaro stalls at low rpm. when I try to
Start out by checking for vacuum leaks.
Jun 09, 2009 | 1996 Chevrolet Camaro
Dodge ram RPM's drop/stall when i start truck
Rad shops have a dye they can add to coolant, then run the engine & with a black light see traces wherever the leak may be, as well as your tailpipe.
Apr 12, 2009 | 1997 Dodge Ram 1500 Club Cab
Stalling on our 96 Dodge Caravan
Once a filter plugs its pluged. You drop that much pressure its time for a new fuel pump.
Mar 21, 2009 | 1996 Dodge Grand Caravan
1996 Dodge Ram 1500 kept stalling while driving now won't start
First off you can test the fuel pump 2 ways
1.have a assistant turn on the ign to on while you listen for the pump to run at the gas cap (gas cap off).
2.find the valve on the fuel rail looks like a a/c or valve stem,take the cap off and press the needle and if fuel comes out then it's not the fuel pump.
But from a lot of EXPERIANCE on dodge engines the stalling and restarting issue is ignition related i.e crank or cam sensor which will throw a diagnostic code of engine misfire xxx cylinders.
So If its one of those sensors then you will not have any spark,and staring fluids will not fire the engine.
As for the headlights flickering they get there power through a relay straight from the battery,so I would look at the relays under the hood and find the one for the headlights and swap it out with the horn relay as most of the relays will have the same numbers.
The crank sensor is about 70.00 and the cam sensor is about 50.
depending on where you get them (dealer or aftermarket)
the cam sensor is the round plastic thing under the dist cap,and the crank sensor is on the pass side under the head into the top of the transmission bell housing and it's a 2hr job to change because of it's location is really hard to get to.
Hint -take the breather off and place a rag over the intake and a board from the radiator core support to the intake to lay on,it has 2 10mm bolts and the wiring harness unplugs from underneath.
Dec 20, 2008 | 1996 Dodge Ram 1500 Club Cab
1996 dodge ram 1500 4x4
toasted fuel pump from running ti dry
Nov 09, 2008 | 1996 Dodge Ram
Dmm Vacuum and Fuel Pump Tester Kit Logo
62 people viewed this question
Top Dmm Measuring Tools & Sensors Experts
Vuk B
Carlos Elizondo
Carlos Elizondo
Level 1 Expert
Are you a Dmm Measuring Tool and Sensor Expert? Answer questions, earn points and help others
