Question about T-Mobile Sidekick® 3 Cellular Phone
Top left button
The tope left button with the 3 lines isn't working. I haven't dropped my sidekick OR have gotten it wet. I can't even press it and t he back button to unlock the phone. I can't press it to create a new message either. Whenever I do press it the call log button may open up or the soundprofile box will open. Then whenever I try to scroll with the ball it will just go from the top to bottom. the only thing that has been working is if I turn the phone off then turn it back on and then I can only accept a call or maybe make a call or text BUT when I go to touch the top left button it messes up again!!! I have taken out the sim card and battery and let it "airout" a bit but it still keeps doing the same thing!!!
  • jordan boy May 13, 2008
    i have the same thing i dont know what to do i need help!
  • Anonymous Mar 21, 2014
    Model ZTE V768
  • 94 Answers
This is obviously a technical problem , i cant suggest anything accept from take it to a shop it will cost quite alot abou 40 pounds but it will be took care of profesionaly, Sorry for my lack of suggestions
Posted on Oct 17, 2007
6ya staff
SOURCE:
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
It freezez a loy
the button probley got wet or if not it has a bad fuse and cnt work through so u have to get it fixed
Feb 20, 2009 | T-Mobile Sidekick II
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 08, 2009 | Sony Z310a Cellular Phone
Sidekick 3
when it turns on it will say "Waiting for activation," when it says this press the menu, or top left black button and "L" hold for about 3 seconds.
Sep 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
call the sidekick help line, (number is on tmobile.com site) they give you a hotkey to fix this, and the ball if it sometimes quits working you might have to change the sensitivity, or the tmobile hotline the guy will ask you to send it in
Aug 15, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Unlock Sidekick ID
I found this guide online.
Please let me know if this works!
"1) Insert the ATT SIM card into the back of the T-Mobile Sidekick ID (it should be located behind the battery).
2) Turn on the Sidekick ID, wait for the screens to load.
3) When the screen says "Waiting for Activation", hold the top left button (the "Menu" button with the three lines) on the Sidekick ID and hold the letter "L" on the QWERTY pad at the same time. After a few seconds, let go of the buttons.
4) If Step 3 is done correctly, the Sidekick should be directed to the jumpscreen and display all of the Menu's of the Sidekick ID.
Jul 13, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick lx
while your on the privacy lock you press the call button 2 times, then the emergency call shows up , once that shows up yu press the menu button (the top left button w. tha 3 lines) while holding shift & Q .
& a message pops up saying if you want to reset to factory settings n yu juss press reset & it takes outt tha code n all tha things in the sidekick ..
your welcome :]
May 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Unlock sidekick 3
there is no code but there is a way press r hold r down take out the battery cap take out battery but continue to press r then put battery back in still dont lety  go of r then put cap on and wait till it starts to turn on once it ha all 4 icons let go of r and it shud turn on and notbe locked no more
Mar 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Settings on a sidekick
pretty simple, the menu button which is the botton on your sidekick marked with 3 lines, one under another. (top left hand corner of face of sidekick)...your questions seems like you want more to add tho
Feb 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3 buttons
The keys may have gotten dirty. So when you push one, it also activates ones near by.
These tips apply to the trackball but you can also use them for the keyboard.
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Jan 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
49 people viewed this question
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Damen Wong
Damen Wong
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
