Lg wm2487hwm diagnostics - Washing Machines
How to replace a washer pump lg WM2487Hwm just a nose from pump....
pretty straight forward job. but you need to take front off for access. which means top comes off first. so must unstack washer/dryer. check out repairclinic.com or appliancepartspros.com for how to videos.
Oct 22, 2016 | LG WM2487HWMA Front Load Stacked Washer /...
LG washing machine WM2487HWM error code pf
Check that the terminal wires are properly connected to the pump unit, or it may be the sensor for the pump phase is shot.
Nov 13, 2013 | Washing Machines
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
We have a LG washer, model wm2487hwm, seems like it is not spinning oiut the water like it used to, clothes seem to be wetter than previously, whats the problem?
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 08, 2011 | LG WM2487H Front Load Washer
LG Tromm washing machine model WM2487HWM has an error code. First letter looks like a capital E without the top horizontal line. second letter is an E
That's 'te' standing for temperature error/ heating error. Before you call an engineer try emptying the washer then pouring a couple of kettles of boiling water into the drum and leaving for 30 minutes then see. Another thing is to empty a couple of packets of limescale remover into the drum together with a couple of kettles of boiling water (again!) and leaving overnight. It possibly needs de-scaling anyway ;-0) If these fail it will be an engineer call, sorry ;-0(
Good luck, John C
Mar 22, 2011 | LG WM2487H Front Load Washer
Rear bearing is going out (very loud on spin). Tech said it would be $900.00 to replace. Is it that hard to replace a rear bearing? Does the whole machine have to be disassembled, etc. About how much is...
rear bearing is generally included with the rear outer drum ***'y. seals and bearings are already pressed into it. it will require much disassembly of machine. hopefully, the motor rotor/stator/drum spider shaft is not damaged too.
Aug 13, 2010 | LG WM2487H Front Load Washer
Lg washer won't spin
Does it power on?
Does water come in at the beginning cycle? Do the lights come on?
Your motor has a warranty of 7 years from purchase date. Call 1-800-243-0000 for service.
Jun 16, 2009 | LG WM2487H Front Load Washer
Need Directions on how to use machine
Hello maemaez4,
I will put a link below which will take you to a web page with a downloadable PDF owners manual for the Tromm. You will have 4 different options,( WM2487HRM, WM2487HRMA, WM2487HWM, WM2487HWMA ) just click on the model of the one you have and it will give you the correct manual. Hope this is what you were looking for.
http://us.lge.com/support/download/search/1000000376_EN_OM_WM2487.jhtml
Thanks,
edgin96
May 19, 2009 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
