Question about Brother MFC-9120CN Multifunction LED Multifunction Laser
MFC 9120cn: paper jam tray message, there is no paper jam, I have thoroughly cleaned the paper pathway and still says there is a jam
Soulvisitor
  • 1113 Answers
SOURCE: can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Posted on Oct 16, 2007
checkitright
  • 1362 Answers
SOURCE: Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Posted on Dec 26, 2007
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
SOURCE: Paper jam Brother MFC-215C
Thanks, your suggestion led me to the solution, the jam not in the rollers or a senser, but it's in the dock of the printer head, when the printer head moved across, I shone a torch into the dock and saw a black thing, so eventually pulled it and realised that it was paper and it had been dyed black by the ink so that's wht it would be hard to spot!!!! Thanks again
Posted on Apr 29, 2008
  • 120 Answers
SOURCE: paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
Posted on May 09, 2008
My printing is fine in the morning but as the day goes on it fades.
Sounds like your printer needs a thorough manual cleaning. Go to printerhacks.com to get step by step instructions
Jul 03, 2015 | Brother MFC-9120CN - 17 PPM Multifunction...
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Paper jam
there must be a little paper left from a jam or there is too much paper in the tray
Jul 12, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
MFC 7420 front paper jam
First you need to clean up your printer with duster and after thatn, check the toner and drum to see any paper jam or anything wrong,
Normally after you clean up the machine, should working fine,
if still not working, please replace the rubber roll.
Apr 06, 2009 | Brother MFC-7420 Printer
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Phantom Paper jam
Pull out the paper tray, shut off the printer.
check all paper path.
turn on the printer
inser the paper tray.
Aug 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC-9120CN Multifunction LED Multifunction Laser Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
