Question about Jacuzzi Pool & Spa
PDC hot tub is tripping breaker - Jacuzzi Pool & Spa
  • 2,760 Answers
Most breaker trips are from water leaks (inside/out and outside/in) and bad heaters in hot tubs i have found
Posted on Sep 19, 2014
djxtreme979
  • 151 Answers
SOURCE: 115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Posted on Dec 28, 2008
zeusfaber
  • 247 Answers
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
  • 165 Answers
SOURCE: hot tub breaker tripping after shorter and shorter
Breakers can grow weak---replace with new breaker.
Posted on Feb 28, 2010
Coastsider
  • 331 Answers
SOURCE: Hot tub breaker not tripped but nothing works
Sounds like your controller has sustained damage. You need to have a professional inspect it to determine what has gone wrong.
Posted on Apr 14, 2010
  • 17 Answers
SOURCE: aqua spa pack breaker tripped
A breaker trips if it getting feedback. Feedback can be caused by water or a crossed wire, or an electrical component failure. You said it's pumping water on the ground so the pump is working. Then if you put it back in it trips, so you pump isn't able to push the water to where it has to go and therefore your getting a pressure buildup which falls back on the pump sensors and stops it before you blow up something, it is saving you from disaster of property or personal injury, this is a good thing. You have a clog in your pipes or you have a valve that is closed that shouldn't be, but it's the back pressure that is blowing the breaker I think. I take it it is on an isolated circuit in your house and isn't sharing anything else that could be drawing to much on that circuit. Anything electronically new in your house? I don't think it's electrically related just asking.
Posted on Jul 14, 2012
Great lakes maniste hot tub comes on click like breaker tripping in tub, could it have bad fuse in tub itself?
Does the breaker trip instantly or does it take a minute? If there is a delay i would start with checking heating element. Instant is a direct short, try unplugging all components and if still trips then check wiring and breakers. If power stays on with components unplugged, plug them back in one at a time to see which one causes failure.
Feb 22, 2017 | Pool & Spa
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
HotSprings hot tub trips circuit breaker
Could be a wrong breaker for that circuit or a problem with the tub.
• first see if there are other lines on that circuit- should be only the tub.
• Check the specs for the tub that the circuit is the correct amperage.
• if clear on those items, there is a problem with the unit and that's another question.
Aug 16, 2014 | Electrical Supplies
Hot tub breaker trips but only when people are in it?
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
Nov 17, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
My breaker is conected to a hot tub. tub was working fine in auto mode. Turned on jets and breaker tripped. will not reset can you help me
I am assuming this is a GFCI circuit breaker? If it is it will have a "test" button on the breaker. When you say "jets" i'm assuming you mean when you turn on the blower to make the air bubbles? It could be you have a problem with the blower motor. When you start the blower, it trips the breaker. Be sure the blower is in off position when you reset the breaker. The most common fault though on a spa/hot tub is with the heater. If the element goes bad, and current flows to ground, it will trip the GFCI breaker. Again try and turn all functions off. Reset breaker, and then turn on one at a time till the breaker trips. First the pump, then the heat, then the blower.
Oct 06, 2010 | Square D Trilliant 40 Amp Circuit Breaker...
My hot tub still trips the breaker,and i replaced it with a new gfci. What other things can i ck.
If your hot tub is pulling more amps than amps sent your breaker box, you'll keep tripping the breaker. Check the rating on the hot tub and compare that to the breaker rating. You may need to uograde the wireing. Make sure the wire gauge is up to code.
Mar 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
Nov 29, 2008 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Pool & Spa Logo
100 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
