Question about Navien NP-240-NG Tankless Condensing Gas Water Heater 98% - 199,000 BTU
Navien NPE240a ng, error code E515 - Navien NP-240-NG Tankless Condensing Gas Water Heater 98% - 199,000 BTU
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
Error code tankless gas
E2 is a cold water inlet temp sensor. Has your unit experienced any freezing conditions? If it senses below 36 degrees or above 90 degrees it will show this error.
If its normal temp, and you still get this error...check your sensor. Its an 8(kohm) sensor. Make sure its not open. If it reads ok and your temp is not an issue, then you probably have a bad control board
Dec 15, 2013 | Bosch AquaStar 2400ES-NG
Noritz Boiler NH-1501-DV-NG Shuts off at radom times with blinking error code 123
error code 123 is a flame rod sensor problem. Chances are the flame rod is sending a weak signal to the control unit. Check for a loose flame rod electrical connector. Peek in the flame inspection windows to ensure there is a proper flame on that side of the burner. If non of the above then try removing the flame rod and cleaning with 400 grit sandpaper or replace it with part order # SKC7448 (called an Ignition plug ELV & Packing EHK SETV)
Dec 16, 2012 | Noritz NH150-DV-NG Indoor Direct Vent...
E9 error code
Before calling service technician, copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Bosch_E9_troubleshooting.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
You should delime water heater once per year to prevent many common error codes.
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
Aug 23, 2012 | Bosch AquaStar 2400ES-NG
E7 code what to do ?
Before calling service technician, call Bosch. 800-642-3111
E7 is not shown as common error code.
Error codes are considered start-point for troubleshooting.
Open following links for general Bosch troubleshoot resources:
Common error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Service bulletins for reading how to fix tankless yourself:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/ServiceBulletins/tabid/1300/Default.aspx
Aug 27, 2011 | Bosch AquaStar 2400ES-NG
Error code E9
High pitched noise is from a very high CO2 level. Adjust the gas pressure to stay above 11" w.c. and have a gas technician with a calibrated CO2 analyzer adjust the CO2 levels.
Apr 21, 2010 | Bosch AquaStar 2400ES-NG
Error Code EA - not in owner's manual
Think maybe just loose connect to me.
Mar 13, 2009 | Bosch AquaStar 2400ES-NG
Navien NP-240-NG Tankless Condensing Gas Water Heater 98% - 199,000 BTU Logo
118 people viewed this question
Top Navien Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Navien Water Heater Expert? Answer questions, earn points and help others
