Question about Levana Lila Digital Baby Video Monitor
Screen goes black when plugged in - Levana Lila Digital Baby Video Monitor
Screen goes black after plugging in charger.
I had problems with my laptop also. My screen would go black, backlight, I could see my screen if I shined a flashlight on the screen. If I opened the screen quickly I could get it to turn back on.
I replaced the inverter board, as mine was a cfl back light for a lcd. Inverter was weak. That helped but I still had some problems with screen not turning on. I found that I had a magnetic lid close switch. I took a magnet and ran it around the edge of the laptop until I located the switch, would turn off the screen. I rubbed circles with the magnet above the switch, med powered magnet from a magnetic screw holder bowl. So far my laptop shut off problem seems to be fixed. Working very well.
Before I ran the magnet over the switch my computer would also shut off when I pulled out the AC plug. Stopped after magnet. I think something gets magnetized and causes problems and magnet corrects problem. You might try this, couldn't hurt.
Mar 31, 2014 | Sony VAIO Computers & Internet
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
My sansa e260 goes black after showing sandisk start up screen and does the same when plugged into a pc. it starts to refresh database and then the screen goes black.
Hi there
When you say the screen goes black even after disconnecting the device from computer it could be an issue with the firmware.
It might need to have updated firmware. To get the updated firmware please go www.sandisk.com.
Where you can get the latest firmware for your model.
*** Make sure when you update the firmware keep the device in MSC mode.
Here is the link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Kindly revert for further clarifications....
Feb 17, 2010 | SanDisk Sansa e260 MP3 Player
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
Screen gone black
Sounds like the screen inverter may be going out. The only real way to check it is replace it or take it to a shop and have them test it.
Jul 04, 2008 | Dell Inspiron 6000 Notebook
Screen goes black when a/v cord connected
I had a bad cable on mine. Once you plug the cord in the camera controls will appear on the screen. If you get a hold of Sony they can get you a new one.
You might be able to find a new one at a computer store depending on what connection goes to the back of you camera to get it to work (like a mini jack).
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Levana Lila Digital Baby Video Monitor Logo
65 people viewed this question
Top Levana Radio Communications Experts
eradiostore
eradiostore
Are you a Levana Radio Communication Expert? Answer questions, earn points and help others
