Question about Craftsman 20 hp 42 in. Deck Yard Tractor
I need to know how to replace the Blade Clutch Assembly Manual on a Craftsman Mower model number 917-288260
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 246 Answers
SOURCE: Need an owners manual for a craftsman lawnmower model 917254240
Hello kwoody2315:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
How do I replace the Blade Clutch Assembly on a Craftsman mower, model 817.288160?
There is one bolt in center of pto clutch. Its best to have an impact to remove this. If you try to remove with a wrench engine will spin. Remove both belts first. Then simply unplug the PTO, Use impact wrench and remove center bolt and gently pry off. Installation is the reverse order.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Oct 15, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to install Mower blade drive belt on 19.5 HP Craftsman 42" Lawn Tractor-Model # 917.270810, without removing mower from tractor.
Hi donsig245,
What I do is to drop the mower assembly to the ground, then I have enough room to install the drive belt without having to remove the mower assembly. You could put the tractor on blocks to lift it up higher so the mower might go a little lower, but it is the same procedure to install the belt. That is the only way I know to install the belt without removing the mower assembly. I know this is not what you wanted to hear, maybe somebody might have another idea that would help you. Regards and good luck.
Mar 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to remove the starter clutch housing (Original part number is 212131 in the Illustrated Parts List online at briggsandstratton.com.) from the vertical crankshaft of a Briggs and Stratton engine, Model...
Brace the mower blade against the housing of the mower with a block of wood, so that the blade cannot turn.
Using a Strapwrench, a chainwrench, or a pipewrench, secure the lowet part of the starter clutch assembly in the wernch and turn it counter clockwise, looking down at the top of the engine.
Aug 12, 2010 | Briggs & Stratton Garden
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hello, I have a Craftsman Model 917.377790 lawnmower, power-propelled, with Honda 5.5 HP engine. I replaced the belt that provides power to the rear wheels. The belt is ''caged'' by other parts, so I...
Sounds like you lost the drive key out of the crankshaft, it's usually half-moon shaped and keeps the blade hub and the crankshaft turning together, the bolt just holds it all on the end of the crankshaft.
Hope this helps!
Jul 03, 2009 | Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
22 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
