Washing machine wont drain
When my drainage pipe is attached up to my sink it doesnt seem to pump the water out but if my pipe is flat on the floo into a little bucket it drains could you please tell me what the problem could be
  • dizzycow2007 Apr 25, 2009
    ive checked for any blockages but doesnt seem to be one
  • 113 Answers
There is most likely something stuck in the pump or a bad pump
Posted on Apr 24, 2009
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
Front loading Washing machine Bendix BIW 150 seem to work fine but after main cycle will not enter into rinse or drain modes. If I select them one y one i will rinse but ont drain. I have to undo the valve...
Check filter first , then make sure the blades are turning ok the pump is fine is the outlet at the sink blocked does it pump freely into a bucket yes ...fault at sink ...
Feb 04, 2011 | Tricity Bendix Washing Machines
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine. Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor. pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards. If the pump is too old or worn out then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
What does E7 mean, or what area needs repair when E7 code comes up on a Samsung wf306lawxaa ? It won't run, but it will drain and add water. The tub moves when pushed by hand, but I can hear change...
Hi, these error codes are to do with water supply and drain.Check the water supply has not been turned off or is not working for any other reason . Outside work can often disrupt water supplys! Blockages of the pump and filters need to be checked also is the drain pipe at the correct height (at least 18 inches/45cm from floor) and if pushed into a stand pipe , not pushed to far down (12 inches/30cm is usually suffice). If your drain attaches to the sink waste , check the nozzle is clear and drainage is good.
Take care
Jun 25, 2010 | Washing Machines
Agitates but wont drain
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care
May 30, 2010 | Kenmore 22422 Top Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Danby add water cycle, water being pumped out.
The pump acts as the drain valve. It sounds like the pump check valve is not working and you will probably have to replace the entire pump. The pump is fairly easy to replace.
Verify that the outlet from the pump goes directly to the drain hose. If so, the only other thing you can do is remove the drain pump and disassemble it to see if something is stuck in there or something. However, this is a more advanced procedure so I would recommend against it. Replace the pump.
Sep 12, 2008 | Danby DWM99W Top Load Washer
The washing machine is sending the waste water into the sink
the drainage pipe under the sink is clogged so when machine releases the waste water it goes in the drain slowly so it come up in the sink you have to clean that drainage pipe under the sink
May 05, 2008 | Washing Machines
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
