Question about Disney Interactive Ariel's Story Studio for Windows, Mac
Can't download ariels story studio on 64 bit version of windows
What should i download to get 32bit operating system software
What is the difference between 32-bit and 64-bit versions of Windows?
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information.
The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. How can I tell if my computer is running a 32-bit or a 64-bit version of Windows?
To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
1. Open System by clicking the Start button , right-clicking Computer, and then clicking Properties.
2. Under System, you can view the system type.
If your computer is running Windows XP, do the following:
1. Click Start.
2. Right-click My Computer, and then click Properties.
If you don't see "x64 Edition" listed, then you're running the 32-bit version of Windows XP.
If "x64 Edition" is listed under System, you're running the 64-bit version of Windows XP.
Download it here:
https://www.microsoft.com/en-in/software-download/windows8
Mar 29, 2017 | Computers & Internet
Upgrading windows vista 64bit
Did you download your Win7 upgrade or did you buy a boxed copy? If you have a boxed version, check in the box. My Win7 upgrade came with both the 32-bit and the 64-bit DVDs in the box. Try using the other optical disk in the upgrade package. If only one disc is in the package, contact the source where you got the upgrade. Only the package for installing a new OS (OEM or full version) comes with just the one disc included. For those, you need to specify the type of system on ordering.
If you downloaded the upgrade, you will need to get a different upgrade file and burn it to disc or make a USB installer for that version of Windows 7.
To confirm your current version of Windows, click Start and choose the Control Panel. Click on System and Security and then on System. This page will display the Windows version and append x64 if you have the 64-bit version.
Alternatively, download the Windows 7 Upgrade Advisor, http://windows.microsoft.com/en-us/windows/downloads/upgrade-advisor , and it will confirm if your system is compatible with Windows 7 and which version you need.
I hope this helps.
(even the Windows 8 upgrade came with both the 32-bit and 64-bit DVDs in the box.)
Jan 05, 2014 | Toshiba Satellite Computers & Internet
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
When insalling my phone to my laptop which is a samsung diva it says no nps exists..what i it? how do i solve the problem?
This is a fairly common problem with samsung media studio and 64 bit versions of windows. If you have a 64 bit version of windows, try running your samsung media studio in 32 bit mode.
Other people have found that re-installing the samsing PC studio can be helpful, and further people have done this to counteract the entire ordeal:
1. choose to save files to memory card, not phone.
2. make sure files are saved to memory card on phone, not internal memory.
3. select mass storage mode on phone
4. connect with usb cable
5. pc recognises memory card on phone as external drive, so you can access files.
May 03, 2011 | Cell Phones
I really love this program. I have recently upgraded my computer to Window 7 64 bit and this program runs 16 bit is there any way I can make windows 64 bit compatible with this program.
There is a way of having micrografx draw install and run properly on windows 7 64-bit and also 32bit
The discovery is that most of these programs are not really 16 bit
If you want check out the website at
http://micrografxdraw64bit.site40.net/
If you want more evidence of this let me know
Feb 03, 2011 | Micrografx Small Business Graphics and...
I`m thinking of purchasing Imagination Studio Suite 2, but I`m not sure if it will work on my laptop. The product needs 2GB of RAM, and my laptop has 4GB. But I think about half of the RAM is being used,...
Yes it will. Having 4GB RAM means you have 64-BIT OS. IN their FAQ Sony explicitly states: At the present time, these programs are supported on Windows Vista 64-bit operating systems: Link.
A requirement of having 2 GB RAM is a minimum requirement It does not mean the program will use all the 2GB space. It means: Windows programs + IS2 needs 2 GB min for stable performance.
However I advise you to download or request for a trial to ensure complete compatibility with the 64 bit OS.
Oct 30, 2010 | Sony Imagination Studio Suite Full Version...
Productivity studio wants Msofts .NET Framework version 2 - The download says not good for 64bit PC - what is correct substitute? Running Win 7 on Dell Inspiron, reinstall following last PC death.
I suggest you install the Lexmark software using the driver from the Lexmark website. First, check if your Windows 7 is running on 32-bit or 64-bit operating system by going the Start menu > right click on Computer > Properties. Then, download the driver using this link: http://bit.ly/dmlCyX (for 32-bit) or this link: http://bit.ly/9drb4y (for 64-bit). Execute the file and follow the instructions on the software. Thanks.
Aug 20, 2010 | Lexmark X4650 InkJet Printer
Toshiba e-studio161 - windows7 64 bit
For Vista there is only a 32-bit driver. I've already tested, it doesn't work
Dec 09, 2009 | Toshiba e-Studio 161 Copier Copier
ITunes ''not responding'' using VISTA 64-bit
are you running itunes 64 bit? that would be your solution there. download the 64 bit version and it'll solve all your problems.
Aug 03, 2009 | Microsoft Windows Vista Home Premium...
Disney Interactive Ariel's Story Studio for Windows, Mac Logo
85 people viewed this question
Top Disney Interactive Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Joseph Hoffmann
Steve Mason
Are you a Disney Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
