Question about Motorola AP 6521 Access Point
Reset default factory settings - Motorola AP 6521 Access Point
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
Tip
CHINA PHONES CODES
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile
china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
also
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes 3xx, 5xx:
software version: *#79#
software version: *#837#
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG:
software version: 2945#*#
Service codes Sony-Ericsson:
J100 software version: #82#
Service codes Fly:
2040(i) reset defaults: *#987*99# Send
MX200 reset defaults: *#987*99# Send
MX200 software version: *#900# Send
SL300m reset defaults: *#987*99# Send
SL300m software version: *#900# Send
SL500m reset defaults: *#987*99# Send
SL500m software version: *#900# Send
MP500 reset defaults: *#987*99# Send
MP500 software version: *#900# Send
Set language to English: *#0044#
Set language to Russian: *#0007#
Service codes Konka:
C926 software version: *320# Send
C926 set default language: *#0000# Send
C926 set English language: *#0044# Send
Service codes GStar:
GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
ZTE Mobileyahoo15.gif1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatelyahoo15.gifE205
unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
Service codes BenQ:
Service codes VK-Mobile 3xx, 5xx:
service menu: *#85*364# (hold #)
Service codes LG:
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly:
M100 software version: ####0000#
Service codes Motofone-F3:
Motofone F3 software version: **9999* Send
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
Service codes Motorola:
C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
C138, C139, C140 software version: #02#*
C155, C156, C157 software version: #02#*
C257, C261 software version: #02#*
V171, V172, V173 software version: #02#*
V175, V176, V176 software version: #02#*
C168, W220 software version: *#**837#
W208, W375 software version: #02#*
and "yes"''
-mobile Inno30, 55, 89, 90, 99, 100, A10, A20, P10, Vk200
- Set full factory *741*737381#
- Set full factory *741*7373868#
- Set full factory *741*2878#
- Set Engineer Mode *888*888#
- Check software version *888*837#
I-mobile 100 ,200 , 313
- Check software version #*888#
I-mobile 309, 310
- Check software version *0*4636#
- Test Mode *0*6268#
I-mobile 311
- Check software version #*878#
I-mobile 511
- Check software version *1222*1#
I-mobile 301, 302,308, 508, 601, 602, 603, 604, 606, 611, 901, 902
- Check software version *#159#
- Set Factory Mode *#32787#
- Set Engineer Mode *#3646633#
I-mobile 503, 506, 605, 600, 607, 608
- Set Engineer Mode ***503#
- Set Factory Mode ***504#
- Set Auto Test ***505#
I-mobile 509, 612
- Set Factory Mode *#66*#
I-mobile 504, 505, 803
- Check software version *68*48#
- Set full factory *789#
- Test Mode *#789#
I-mobile 305, 306, 315, 510, 609, 609i,516
- Check software version *#8375#
- Set Factory Mode 878
I-mobile 610
- Check software version *#22#
I-mobile J101, J102
- Test Mode *23638777*783781#
I-mobile 502, 502i, 505, k9, 802
- Check software version *201206*4636#
on Mar 11, 2008 | Nokia N95 Cellular Phone
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
I need a code for a kodakhero printerphotocopier 7.1
I don't believe that model has a password. You may just need the password for the network you are using. If you want to reset the unit to the factory defaults see below.
To reset defaults to the factory default settings:
1. Press .
2. Touch , then touch Printer Settings.
3. Touch , then touch Reset All Settings.
4. When you see the message, "This will reset printer settings to factory defaults,"
touch Yes.
NOTE: Resetting factory defaults does not change the date and time, language, or
country/region.
Jun 19, 2014 | Netflix
Go back factory condition
Hello Cynthia,
There are several ways to achieve this.
Reset phone
The Reset feature allows you to set your phone options back to
the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone -> Reset phone.
  2. At the "All settings reset to factory defaults. Continue?" prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Restore phone
The Restore feature allows you to delete any user information
that has been added, in addition to setting your phone options
back to the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone ->Restore phone.
  2. At the "All settings reset to factory defaults and all user data will be deleted. Continue?" prompt, touch Yes to reset, or No to cancel.
or
Reset code
Enter *2767*3855# in phone dial.
Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup on your PC before full reset!
Dec 06, 2013 | Samsung SGH-A877 Impression Cell Phone
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
Motorola AP 6521 Access Point Logo
24 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
