RCA MODEL R56WH78; Has a convergence problem. Fuses around flyback, FL221,231&251 all ok. DC voltage of convergence pwr board. BP611=165V, BL670=236V,BL680=65V,no voltages on the secondary of transformer diodes, BL600 pin 1=-13v,pin6=+13v; BP660 pin6=+11v, pin10=-11v. TP630 has been replaced.
  • 1 more comment
  • wgbandy Apr 26, 2009
    Dear e-Guru;
    No I DO NOT accept this as a solution to my problem. The information you 've provided is common knewlege. I know a repairman will charge X amount of dollars to fix this, but my request to you is to be put on the right track to begin trouble shooting this problem. As with the info I've already supplied I do have some expericence in trouble shooting electronics. Both the conv. bd & the pwr supply bd have been repaired by a service center. Flyback resoldering was no help. Give me something to go with. Bandy
  • wgbandy May 18, 2009
    You must be working with another RCA model. This model #R56WH78, chassis #ITC222A DOES NOT have these ICs. Nor does the pwr bd. This conv bd have a series of transistors of the TO 220 three leg type, all checked good. Willie.
  • wgbandy May 27, 2009
    You are correct in that the set-up step you suggested in solution #2 Do Not apply to my set. Additionally; a review of my original problem, no convergence, you will note that there is NO pwr (voltages) on the convergence bd or the conv. pwr bd. Requesting info on solving this problem. Willie
    Novelist:
  • 130 Answers
First, take a look at the following web site information. Unfortunately, some RCA sets have manual convergence boards - which means you can do nothing but replace it and adjust the manual controls on the board itself.
But some of the newer ones (Maybe yours) can be accessed through the service mode. So, give it a try. I have also copied the part of the web site that gives the entry code to get into the service mode:
Read the _ SERVICE MODE WARNING _ before proceeding.
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
With luck, you MIGHT be able to adjust it back into better alignments.
If you end up needing service, the price of the convergence board - if you can get it from RCA Parts - should not be over $100, but I have not actually checked it lately - and it depends on the model.
The installation is quite time consuming, so it may take a couple of hours for a tech to install and align it.
I encourage you to look elsewhere the RCA web site has a link to authorized service centers; you might try that.
Wishing you the best,
thanks.keep updated.
Posted on May 18, 2009
    Sergeant:
  • 254 Answers
On the convergence board there are two ICs .the number of the ICs are 392------ 100 or if the ICs are little bit latest the number will be 392------- 120.there are two such ICs on the convergence board.and both the ICs have to be replaced to resolve the problem.
you can get the ICs at
www.radioshack.com
replace the ICs and it will start working.if not familiar with it then get it replaced by a technician.the cost of ICs is not more then $40 for both.
thanks.
please do rate the session.thank you for using fixya.keep updated.
Posted on Apr 26, 2009
    Brigadier General:
  • 3,917 Answers
Yes on the Fly back transformer solder all the pins , this can take care of about 90 present of the problems on the model.
The problem is with the convergence. If the focus did not correct the problem likely the convergence IC's have failed and will need to be replaced along with a few defective resistors. A TV repair company will normally charge about $350 for this repair. This is a very common problem with this TV set
. There could be other parts that are not within factory specs. The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test equipment to determine what parts that are no longer within specs. A small TV repair shop will many times be less expensive than a large repair facility.
Thanks
Posted on Apr 24, 2009
R56wh78 im having a problem.. the tv started the 3d effect so i replaced the convergence board.. and fixed the problem for about 2 days (convergence is still good).. now im having a new problem.. the tv...
The Deflection Power board is the the most likeliest cause of the dead set issue, and that could have also caused the prior issue of convergence board since the deflection board supplies all base voltages for the convergence circuits
Aug 16, 2011 | RCA Televison & Video
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Colored lines on top portion of screen with blurry colored picture
Hi:
This is due to a faulty convergence power supply or voltage supply to the convergence board, first thing to check is the deflection board this the board to the right of the unit look at if from the back.
Check all connection on the flyback and resolder is any cold solder joints are found. Also there are tree micro fuses the may of blown if there are any bad connection around the flyback.
Nov 09, 2010 | RCA HD52W56 52" Rear Projection HDTV
Have a yellow and blue hazw from left to righton the people and lettering rca 56 inch tv
Hi: this is dur to convergence board failure, there a three micro fuses on the deflection board power suppply that need checking, also while checking these fuses check the solder connections around your flyback transformer as this is the most common reason these fuses fail. If all fuses are good then a replacement of the convergence Board is necessary at this point.
Aug 18, 2010 | RCA P46810LV 46" Rear Projection...
WHY DOES'NT MY RCA MENU HAVE CONVERGENCE PROGRAM R56WH78 TURNED IT OFF FOR 10 HOURS TO REBOOT STILL NOT THERE
Blowed fuse on the deflection board FL231.06 amps it will be located on the right hand side of the FBT flyback Transfomer
there will be 3 of them in a roll small brown or gray rectangler looking caps but they are fuses it will be the one in the middle
Partstore.com has them. Deflection board is locted on left hand side of bottom chassis.
Jun 05, 2010 | RCA D52W23 52" HDTV CRT TV
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R56WH78 No sound or video
there are 3 fuses by the flyback,check them.also look for bad connections under flyback-also check for a bad connection on the crytical safety cap.if all else fails deflection board part number is 272074,NTA thru rca but tristate module or pts electronics can repair it for you.
Sep 24, 2009 | RCA R56WH76 Projection Television
Convergence problem
Yes, the convergence circuit can fail without blowing any fuses. These Tvs are tough to repair because the convergence output devices are transistors and there will be other small components damaged as well. Get an estimate from a reputable service center before going any further.
michtech
Feb 12, 2009 | RCA R52WH76 Television
Convergence on a r56wh78 rca projection tv
I located the problem with this set and wanted to pass it on to help anyone with this problem. the chassis # is ITC222A and the problem turned out to be a fuse on the High voltage board. There are 3 fuses that sit next to the flyback transformer and the middle fuse (400 ma 125v) was blown.
Mar 21, 2008 | Televison & Video
I have a rca hdtv r52wh77 1 year old ,i have color problems ,i cant get to the convergence set up ,please help.thks
Try looking at the main board very near the flyback and you should see 3 fuse links (they look like hard capacitors) one of them is probably open causing lack or power to the convergence board by way of the ribbon seated close to the vertical output IC
Dec 22, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
317 people viewed this question
Top Televison & Video Experts
Electro Med Services...
