Question about Oggi 6541.0 Lever Pumpmaster Stainless Steel 1.9-Liter Thermal Coffee Carafe
Oggi model 6541.0 When airport is filled with coffee, it flows out of the thermo us on its own all over the cabinet. Tried closing the lid with the lever in the upright and closed position contents still flowed out on its own upon closing the lid.
Just dribbling, not filling up with coffee
If the coffee is flowing over the top and not going through the filter holder. into the flask below, check that there is no blockage under the filter holder or if fitted ensure the anti drip under the filter is open this is usually activated by the lid on the flask, which presses this open to allow coffee to fill the flask, when fitted, then to stop the coffee dripping onto the the hot plate below when removed. so ensure any lid for the flask is fitted and that the flask is in correct position on the hotplate to allow coffee to flow through.
I hope this was helpful.
Apr 04, 2015 | Coffee Makers & Espresso Machines
New fatory reconditioned youbrew. Water doe not flow when brewing cycle is iniated.
If you do not hear it boiling the water, then the heater element is not working. The only other thing that can stop the flow (if the heater element is working) is the cutoff for when the lid is open, but if you assembled it correctly, and the lid is closed, that shouldn't be a problem. Just be aware it won't work correctly unless closed. No boiling sound = return it.
Mar 07, 2015 | Breville Coffee Makers & Espresso Machines
SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
May 30, 2010 | Fisher and Paykel Washing Machines
My Keurig just started only filling my mug 1/2 full on the large cup setting. I now have to run a full cup option, open and close the lid, and then run the 1/2 cup option to end up with a full cup of...
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
Mar 06, 2010 | Keurig Elite B40 Coffee Maker
Just bought a Bunn coffee maker at a garage sale great condition how do you make the coffee I have poured water in turned the side switch on and the warmer switch yet nothing?????
The machine requires an initial set up to be completed before using it. Fill the decanter with cold water and close the lid. It will take 3 minutes to partially fill the water tank in the back. Then fill the decanter again with cold water and pour in and close the lid. Then plug in the machine and turn the vacation switch on the side of the machine on. After 15 minutes, you will be ready to brew coffee. Then you will get your filter basket ready with the filter and grounds. Pour in from 4-10 cups of water and place the decanter on the base. Close the lid and the coffee will begin to brew. If you will call customer service with the model and date code, a use and care manual can be sent out to you at no cost.
Sep 06, 2009 | Bunn NHB Coffee Maker
My coffee maker, Cuisinart dcc 1400 only boils water, does not make coffee. It is one week old. I have a water filter in the plastic filter holder filled with coffee.
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Coffee Makers & Espresso...
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Kenmore Elite coffeemaker - excess steam
Fold a large piece of foil into quarters. Place foil over reservoir and firmly close lid. Open lid and massage edge of foil inside and out with finger to get a kind of cap. Remove foil and trim neatly around outer edge of lip. Fill reservoir with water, place cap on top and close lid. Make coffee.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Oggi 6541.0 Lever Pumpmaster Stainless Steel 1.9-Liter Thermal Coffee Carafe Logo
719 people viewed this question
Top Oggi Home Experts
Donni Steen
Tom Chichester
Are you an Oggi Home Expert? Answer questions, earn points and help others
