Question about Locks & Locksmithing
Gate House electronic keypad #0399129 will not open when code is used but the dead bolt will lock - I cannot even remove the key until I manually lock the dead bolt then I've locked myself out
SOURCE: Lock works in reverse
You need to set the door direction jumper pins inside the unit. From LH to RH or vice versa depending upon your door.
Posted on Jun 01, 2009
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Posted on Jun 09, 2009
  • 963 Answers
SOURCE: the dead bolt handle started turning the wrong way
Here's the info on your lock:
http://www.kwikset.com/Products/Details/Electronic-Locks/909-15-SMT.aspx
Clicking on the link "Installation Guide" will take you through the programming steps:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
I think you'll find your answer there.
Posted on Mar 05, 2011
  • 963 Answers
SOURCE: dead bolt does not align
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
Posted on Apr 18, 2011
  • 15 Answers
SOURCE: Have a Rona electronic lock (Weiser) and the key
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Posted on May 15, 2011
We have several Schlage keypad entry locks. The battery is dead on one lock and it is to the cupboard which contains the manuals, codes and emergency keys! How can we get the lock open or off?
Emergency Key Override.
If you are daft enough to keep the emergency keys on the room locked by the keypad, you need a locksmith and a pik set or pik gun. :>) Lesson learned.
Are you able to push the pins out on the hinges?
Here is the manual anyway.
http://consumer.schlage.com/project%20documents/23780042%20fe%20and%20be-series%20user%20guide-a_web.pdf
Nov 27, 2016 | Schlage Locks & Locksmithing
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
Dead battery power locks
the key will always open the door from driverside
Jan 22, 2013 | 1994 GMC Jimmy
What do you do if the batteries are dead in my Sentry fire safe and can't put code in ?
a1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Security Safe with Electronic Lock...
When we lock the door you just have to press the schlage lever on the top of the elecronic keypad and the door opens. Help we don't want to go to bed with the house unlocked
the lock is set in factory mode and needs to be programed to the security code that you choose.
go through the code set up and program in your code and the lock will work as intended.
if there is a problem with the lock and it will not accept the codes then the only way to disable the motor function of the lock is to remove the battery itself and use the key bypass until you can get the lock fixed or replaced.
c...
Jan 21, 2011 | Schlage Lock BE365VCAM716 Electronic...
I have a kwiklock key pad. when i hit the lock button to leave house it wil not lock. it only locks dead bolt with the code. you can get into the house by just hitting the lock botton and it opens the...
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Dec 20, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Wired alarm beeps every 30 secs. No reset code or panel box.
You may need a code to silence it, but you can try pressing the '*' key on the keypad.
If it is only beeping when you exit or enter through a protected door, you can remove the magnet (likely drilled down into the top of your door(s)).
If it is a low battery, you'll need to power down the system. To do that you will have to access the main control panel, pull either lead from the battery and disconnect the transformer in the house. If you have difficulty locating the transformer, go to your circuit breaker panel and shut down your circuits, one at a time, until your keypad's display is blank--track the circuit to locate the transformer.
Jul 12, 2009 | GE SecurityS754DAT-RST1 Motherboard
Feb 19, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Locks & Locksmithing Logo
211 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
