Question about Dryers
Not functioning properly
My Kenmore 67832 Dryer is not rotating, but making a noise like the motor is running. It still blows hot air and will run through a whole cycle with no other problems though
  • 113 Answers
Check to see if your belt is broke
Posted on Apr 24, 2009
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
Kenmore king size capacity 90 series
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Jan 06, 2008 | Kenmore 63942 Dryer
Clothes are to hot to touch, already cleaned dryer vent and dryer is blowing a force of air out of back and through venting system. Why??
Check to make sure that your cycling thermostat is operating properly. Also make sure that drum is rotating. What it sounds like is that the machine has either an air flow problem or thermostat problem. Try running the machine with the vent off, only if it is electric, not gas dryer. Also check your blower to make sure it is tight on the motor shaft. That would impede air flow and cause overheating.
Jul 31, 2013 | Siemens Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
Maytag electric dryer model MDE6000AYW dryer is running but not getting hot and drying clothes plus making a dining noise every couple seconds while running
Dryer Does Not Run
Your Kenmore Oasis dryer may occasionally not operate as intended. When the dryer does not turn on, check that the power cord is plugged into a working electrical outlet. Check your fuse box to make sure a fuse hasn't blown or the circuit breaker hasn't tripped. Replace the fuse or reset the circuit breaker as needed. Next, check that you have fully closed the dryer door; if not, the dryer will not run. Finally, make sure that you press and hold the "Start" button for at least five seconds.
Dryer Making Noise
Kenmore Oasis dryers will make noises that occur commonly with the running of the machine, including the motor and the sound of hot air blowing into the machine. Listen for uncommon noises with the running of the dryer, such as metallic clanking and excessive vibration. These noises indicate a problem with the machine.
If you hear metallic clanking, stop the dryer and check for any metal objects in the dryer drum. Often, change or other objects left in the pockets of clothing placed in the dryer will then fall out when the dryer starts spinning, creating the noise.
Excessive vibration often occurs when you have not properly leveled the dryer. To check whether the dryer is level, turn it off and try shake it frontward and backward, then left and right. If the dryer moves, adjust one or more of the legs needs to level the dryer: Determine which leg(s) you need to adjust and use a wrench to lengthen or shorten the legs. A level dryer will more quietly due to the elimination of vibrations.
Drying Time is Too Long
You may find that your laundry takes a long time to dry in the Kenmore Oasis dryer. This often occurs due to restricted the air flow within the machine. First, clear the lint filter. Clean it before every drying cycle to ensure proper air flow through the machine.
Next, run the dryer as usual and check the exhaust vent to ensure that airflows out of the vent. If you cannot feel air flowing through the vent, check it for blockage or damage. Clear any objects blocking the vent, or replace it if it has sustained damage.
The blockage may also occur in the exhaust hose attached to the back of the dryer. Unplug the dryer and remove the hose from the back of the machine. Clean out any lint or other obstruction and reattach the hose to clear the exhaust hose.
Mar 09, 2011 | Dryers
My heater blows cold air. I have had it checked. The water is hot and is running properly through. Mechanic had no explanation as to why only cold air was blowing in and not hot.
It seems to Me that, the heatercore is not functioning properly. Its just like a radiator, the hot water runs through the core, once the thermostat opens at it's set temperature and having the blower motor on, it should blow out hot air.
Dec 28, 2010 | 2001 Jaguar S-Type
The dryer isn't drying properly. It gets hot its not drying. Its a Kenmore Elite. Also the coil has been cleaned and its not catching lint.
Make sure the drum is turning and the blower is functioning. Vacuum out all air passages including the hose going to the outside vent. Remove the lint trap, and wash it in hot water and detergent to clean away fabric softener deposits from the screen. If the motor is not running, find out why.
Nov 20, 2009 | Kenmore Elite HE4 Electric Dryer
MY DRYER DOESN'T GET HOT
There are a few things to check out. 1. This may seem obvious, but make sure your temperature switch is not pointed to "fluff/air dry".
2.Is the motor running? It has to, to dry three. Make sure your door switch is engaging properly.
3. If you are so inclined, unplug the power cord and remove the back lower panel of the dryer.) Remove the vent pipe & allow the unit to run, if you now have the proper heat this means the vent is block, check the outside vent hood, the sometimes have a screen just inside that will block up not allowing for air flow.
Check all wire connections to make sure they are attached properly. If they are burned or worn, they need to be repaired or replaced. Any disruption of the circuit to the dryer element will stop its functioning.
4. Next, look for the thermostat.. which is usually a small circular metal device attached to the dryer element canister. Unscrew it and shake it slightly. You should hear a clicking noise. This should indicate that your thermostat is working (but not always!).
5. Remove the heater element canister cover and check to see that there is continuity of the element wires (no breaks). If there is a break, it needs to be repaired of replaced. You can take the heater element to a repair shop and be tested for current. If you think that you can repair any of this on your own, then go for it. Always think safety first before proceeding
Feb 21, 2009 | Kenmore Dryers
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
