Question about Fuji FinePix S2000hd Digital Camera
Needs recharging needs recharged don't have my owners manual. Replaced batteries but charge is still lwo how do I recharge the camera
  • trule383 Apr 24, 2009
    Thank you so much!!!!!!!!!!!!!
  • 289 Answers
AA (4) batteries (NiMH recommended). Walmart sells a recharger for AA batteries. Buy the NiMH type as they last WAY longer than your typical alkalines. If you don't use the camrea for a while top off the charge. If you keep spares charged and they sit for about a month - top them off too.
Posted on Apr 24, 2009
Battery exhausted even after charging.
There are two possibilities. First, rechargeable batteries do not last forever. Take out your rechargeable batteries and replace them with non-rechargeable ones for test purposes. If your camera works ok, it may be that the camera's charger circuit has gone bad. Try charging your batteries on an external charger. If they charge, it is your camera's charger, if they do not hold a charge, it is probably time for new rechargeable batteries.
Sep 11, 2013 | Nikon Coolpix 3200 Digital Camera
Hp photosmart M23: can I charge new batteries in the camera
The batteries can be recharged in the camera with the appropriate adapter or dock. See page 155 of the manual.
Oct 17, 2012 | Cameras
How to charge camera
You don't. The Kidizoom uses four standard AA batteries, either disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger. Rechargeable batteries and battery chargers should be available at just about any department, electronics, or office-supply store.
Oct 06, 2012 | Vtech Kidizoom Digital Camera
How do you charge lumix DMC-LS6 camera
You don't. The DMC-LS6 uses standard AA batteries, either disposables or rechargeables. If you use rechargeable batteries then you must charge them outside the camera using a separate charger. AA rechargeables and chargers should be available at just about any department, electronics, or office-supply store.
Jul 29, 2012 | Cameras
How do you charge panasonic lumix DMC-LS6
Jul 29, 2012 | Panasonic LUMIX DMC-LS6 Digital Camera,...
Dead battery
Be sure to charge your batteries fully before installing them. If the batteries are non-rechargeable, dispose of the old batteries properly, and then replace them.
Rechargeable batteries have a limited number of charge/discharge cycles before they become exhausted. If your rechargeable batteries are dead after a full charge cycle, they may also need to be replaced.
Mar 07, 2011 | Cameras
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Using rechargable battery with new camera for the first time
If you are using a rechargeable battery, yes you should fully charge it before you use the camera for the first time. Rechargeable batteries are normally supplied without a charge from the factory, but not always. Fully charged batteries may be in storage for a long time before the camera is purchased and unlike modern dry cells, rechargables will not hold a charge for years.
Fully charge your battery, then run it until it has completely exhausted. If you plan to put the camera in storage at some point in the future, always recharge the battery every couple of months or so, to keep it in good condition.
Of course make sure the supplied battery is in fact rechargeable and not a lithium which should not be recharged.
If you found this info useful, please give me a thumbs up...
Mar 11, 2008 | Kodak Easyshare M753 Digital Camera
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Fuji FinePix S2000hd Digital Camera Logo
117 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
