XEROX WORKCENTER 5016 PAPER JAM - Office Equipment & Supplies
tommya300
  • 724 Answers
SOURCE: Cleared paper jam, but printer not responding
Did you shut power when removing the jammed paper. If you did not then you have forced the gears against the rotation and may have hurt the transport system
Posted on Jul 27, 2009
  • 239 Answers
SOURCE: Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Posted on Oct 16, 2009
  • 78 Answers
SOURCE: Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Posted on Nov 30, 2009
  • 21 Answers
SOURCE: xerox workcenter tray 1 will A3 size ,if printuing
igual tienes un papel en el fondo q oprime los pulsadores detectores del tamaño del papel
Posted on Dec 02, 2009
  • 1739 Answers
SOURCE: our xerox workcenter m15 had a paper jam. we
The simplest solutions:
Plug a small apliance or light Into the wll otlet to determine if there is power in the outlet
If the appliance does not power ON, the problem is in the power outlet. Contact your building maintenance department to check the breaker in the electrcal panel.
If there is power check that the power cord is securely plugged in to both the wall socket and in to the machine.
Turn off the power switch on the left-hand side of the machine; wait one minute; turn back on.
If these steps do not resolve the problem you may need to contact a service representative.
Posted on Dec 08, 2010
My xerox workcenter 416s has the following error: close offset cover. What is this??
There is a small cover where your paper exits into the tray. It probably is just ajar and not actuating the switch. Check in the area above the right side where you would clear a jam and where the already made copy comes out. Something there is not closed all the way, or the interlock switch has popped out.
Jan 06, 2010 | Xerox WorkCentre Pro 416SI All-In-One...
Nov 29, 2009 | Xerox PE120i Laser Printer
Paper Jam E2 error
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Jul 27, 2009 | Xerox Phaser 6100/BD Laser Printer
Xerox WorkCentre PE120i - Paper Jam 1
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCentre Pro 215 E2 Error Code
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
22 people viewed this question
k24674
jasbo
jasbo
