Question about Panasonic NIA56NR NI-A56NR Iron
Panasonic Iron won't heat
Four year old Panasonic NI-R71NR does not heat up. Where should I start checking?
  • 1,869 Answers
Most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Posted on Apr 24, 2009
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
My iron is not warming up any more what can i do?
A. Check the wire connections. If so, tighteing or chaning the cord with do . B. Thermostat migh got suck, if so, inspection of it will show and you need to gently sand the contact point. Or worst case senario, the heating element (coil) inside the heating plate might have been burnt, is this is the case, the iron is toast.
Sep 19, 2011 | Panasonic NI-A57SR Iron with Auto Shut-off
The red light is on ,but the iron don't get hot
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101/./.
Mar 23, 2011 | Panasonic NI-R73NR Iron
My iron has stopped heating. should i throw it away?
well, most likely. the heating element may have burned out. if you want to get a good iron, then go to a second hand store like good will, and find an older GE iron. those things are the best Irons that my family has ever used.
Aug 12, 2010 | Panasonic NI-C78SR Iron
Iron won't heat up.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Nov 02, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
heatman101
Oct 04, 2009 | Panasonic NIA56NR NI-A56NR Iron
THE LIGHT IS ON BUT THE IRON WON'T HEAT UP.
heatman101
Jul 06, 2009 | Panasonic NI-R73NR Iron
NIA56NR Iron = Panasonic
the filament is gone
u need to replace it from local vendor
Mar 14, 2008 | Panasonic NIA56NR NI-A56NR Iron
My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Aug 11, 2007 | Panasonic NI-R73NR Iron
Panasonic NIA56NR NI-A56NR Iron Logo
788 people viewed this question
Top Panasonic Irons Experts
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
