Question about Compaq Presario 5000 PC Desktop
RAM increment i have a very old compaq presario 5000-G1 PC with a 64 MB RAM,i want to increase the RAM, can any one tell me how much xtra RAM can be added to my PC?
  • Compaq Master
  • 4,338 Answers
You can add up to 512 mb. It has to be PC100 memory . Purchase 2 sticks of the following type:256MB Compaq Presario/Deskpro PC100 SDRAM Memory (p/n 171558-B21)
$19.98
If I coud be of further assistance , let me know. Otherwise, please rate this solution
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 24, 2009
    President:
  • 1,383 Answers
Yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
Please rate this reply - good luck!
Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
What is the most RAM I can add to the compaq presario 5000 I currently have 512 MB RAM
if I am correct you can go up to 2 GB's of system memory 2 1gb sticks each!
Thanks I hope this helps please do rate with the 4 thumbs above.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Feb 13, 2010 | Compaq Presario 5000 PC Desktop
Which ram support for compaq presario c700 tu''
This laptop can have a max of 2Gb of ram, (2x1gb)
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot, None-ECC
Hope this helps.
Aslong as you get 512Mb or 1Gb sticks of PC2-5300 none-ecc laptop ram, you will be fine.
Jan 02, 2010 | Compaq Presario 700 470024-192 Notebook
ATI AGP card and Compaq Presario S3100NX with open AGP Slot
This particular model of the system is basic home use system not built for games.
You can put in either a PCI graphics card or an AGP 4x graphics card that should not take more than 1.5v of power.
The max you can put is 128 MB , you can try the 256 MB, but i would suggest against it .
Thanks for using fIxya
proton
Nov 07, 2009 | HP Compaq Presario S3100nx (DC477A#ABA) PC...
Increasing the capacity of RAM.
According to what I found here, you can increase up to 384 MB RAM.
Jan 03, 2009 | Compaq Presario 700 470024-192 Notebook
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Ram
Check the configuration of your system, it probably supports 128 MB of RAM at max.
Jul 16, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
223 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
