Question about iPhone Apps
Not charging with usb - iPhone Apps
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Tip
Batteries & USB Devices & Charging
I see lots of people have trouble with their batteries for their various USB connected devices. Unfortunately you cannot usually charge a totally flat battery, or even a 1/2 charged one... from the USB port. These are only used to "Top Up" the battery... & keep it charged up via a "Trickle Charge". at very low current.If your battery is in this condition then you need to replace it with a fully charged one, and then use the USB to keep it fully charged.Another way is to connect the "Flat" battery up to a power supply or machine that charges them, at the right Voltage (Usually 3 - 6 V) & Current rating, and once fully charged, then use the USB.
on Jan 29, 2010 | Computers & Internet
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
Nokia 3110c Charger not supported
First Option:
Second Option:
Dec 29, 2010 | Nokia 3110 Cellular Phone
I dont how charge battery on my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Audio Players & Recorders
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
Can i charge the camera other than through the usb cable ??
Hi!
USB charging is not possible. You need to have the battery charger to be able to fully charge the battery. This should come along with the camera kit.
USB charging is possible if you will buy this: http://fujifilm.co.uk/consumer/digital/digital-accessories/usb-chargers-travel-adaptors-153171/world-adaptor-plus-usb-charger
"For charging by USB, simply change the head and plug in your iPod, mobile phone, PDA or any other 5V USB powered device to keep it fully charged wherever you are."
Aug 25, 2009 | Fuji Finepix Z20fd Digital Camera
I cant charge my psp with usb
go to settings and check that usb charge option is on... and ake sure its in usb mode
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
iPhone Apps Logo
110 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
