Question about Kitchen Appliances - Others
Cme256as-1f Scotsman, code says "Harvest cycle time limit reached, ice not sensed". Machine turns itself off repeatedly. Will make ice if you keep turning it on. What's wrong? What can I do? -Dave Quinn.
TheMobilian
  • 8220 Answers
SOURCE: Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Posted on Mar 01, 2009
farfield
  • 462 Answers
SOURCE: Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Posted on Jun 02, 2009
  • 202 Answers
SOURCE: ice sheets too thick to shatter when dropped
timer not working properly replace if necessary
Posted on Jul 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Posted on Nov 05, 2009
SOURCE: My Scotsman machine cme256 take
Problem too long ice production CHECK THE FOLLOWING: check the refrigerant charge check the hot gas solinoid valve compression test the compressor check the ambient and water temp. check the condenser fan motor and condenser coil check the txv and sensing bulb if in proper location
Posted on Jan 10, 2011
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
What can I do to fix cem256 ice machine that the refigeration light blinks twice ?
http://hvac-talk.com/vbb/showthread.php?679751-Scotsman-CME256-Water-Diagnostic-Light-Problem
May 15, 2014 | Scotsman Ice Machine - 290lb...
Refrigeration code on scotsman ice machine model cme506as-32f.What could be the cause?
Unit is off& Refrigeration diagnostic light is on or blinking. Possible Cause,( Low discharge or long freeze cycle. Probable correction, if the Refrigeration light is glowing steadily there is a probable refrigeration problem.) 2. Possible cause. Harvest problem. Probable Correction. If refrigeration light blinks once and repeats, Look for a harvest Problem.**On Controllers 17-1 and higher, This also indicates that cubes were (sensed) by the bin controls. 3. Possible Cause. Hot gas valve failure, Probable Correction. Check hot gas valve operation. 4. Possible Cause, High Discharge Temp. Probable Correction, If the refrigeration diagnostic light blinks 3 times and then repeats, check for a reason for high discharge temperatures. 5. possible Cause, Harvest problem. Probable Correction, Controllers 17-1 and higher, if the light blinks 2 times and repeats, check for a harvest error- no cubes sensed. 6. Possible Cause, Unit dose not go into harvest - exceeds maximum freeze time. Probable Correction, Push and release off button. Push and release Freeze button. Check operation. next Push cube size float down and check operation. 7. Possible Cause, Exceeds maxi harvest time. Probable Correction, Check for cause of long harvest cycle. Try not to put any gauges on system until you have to. Every time you do you loose refrigerant out of the system.
May 02, 2014 | Kitchen Appliances - Others
Model CME256AS-1D will not go back into freeze cycle and will eventually stop, requiring the unit to be reset.
So is the unit going into a harvest and not going back to a freeze cycle? dose it dump a batch of ice but wont go back into a freeze cycle? before you reset it have you pulled the front cover to see what code it is giving? any time you have to reset it that means it locked its self out on a fault. if unit freezes and go's into a harvest and dumps the ice but dose not go back into freeze cycle check the door switch when the ice dumps the deflector door opens a magnetic switch which tells the board the harvest has finished and then the freeze cycle begins. Now if there is no ice falling off the plate to open the door then the board will time out and try 3 more times to make ice before it locks it out. the same go's for the harvest.
Jan 08, 2014 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman cme256 as-1d sticks in harvest cycle
The only thing that tells the machine that a harvest cycle has completed and takes it back into a freeze mode is the ice level control. when the machine go's into a harvest the ice drops through the ice level control and brakes the beam and switches the machine back to freeze cycle. Pull the the ice level controls and replace them. if there is nothing wrong with them than it is the electronic controller. part number for ice level controllers are 11-0540-21. The part number for the control board is 12-2838-24
Dec 07, 2013 | Scotsman Kitchen Appliances - Others
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotsman model 506as 1f, serial no. 06021320015994. Was running fine until i had it sent in to a local shop for routine check up during the normal winter down time for the machine. When i started using...
Have you pulled the cover off so you can see the code it is giving really need to know it. sounds like either low charge or hot gas valve not opening during harvest. I really need the code to be able to help you out.
Jul 07, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Kitchen Appliances - Others Logo
133 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
