Question about Microsoft Windows 2000 Advanced Server
VNC screen is lookibg black
I am using windows 2000 server and i connect the server through the VNC viewer in windows XP clinet, when i tried to connect the server it always seems a black screen i cant able to get the console through the VNC viewer, but RDP is working fine i am able to get the windows screen through RDP.
The server is production server and application is running in VNC console i cant restart the serivce all the time. It a critical application is running there. I need a permenet solution to fix the issue. if any one know the solution that should be helpful to prevent it from future.
Thanks in Advance.
  • Syed Mohamed Apr 24, 2009
    I am running the VNC server on server not in client
    Hi sir,
    Thank you, i will try this option if it is not work i let you know thanks you very much once again
  • 289 Answers
Make sure you are running VNC "Server" on your server and not the client.
Posted on Apr 24, 2009
  • Fred Block
    Fred Block Apr 24, 2009
    You may want to try disabling any screen saver on the Win2000 server box.
  • hassanahm362
    hassanahm362 Mar 20, 2012
    The main reasons you may encounter this are:
    * You're connecting to Windows Media Center or similar software
    * You're trying to connect to a computer that's using Fast User Switching (i.e. you are in a switched out session)
    The workaround for Windows Media Center is below. We do not support Fast User Switching, the workaround in this situation is to login to a non switched out session.
    This is likely due to the VNC Mirror Driver, which will be attempting to capture the hardware accelerated video / menus, but is unable to do so by design. You can either lower machine hardware acceleration (this shouldn't impact machine performance, depending on the speed of the machine or the graphical intensity of the video) or you can enable a different update method, instead of the VNC Mirror Driver.
    To lower the computer's hardware acceleration:
    Windows XP:
    Control Panel > Display > Settings > Advanced > Troubleshoot
    Windows Vista:
    Control Panel > Personalization > Display Settings > Advanced Settings > Troubleshoot
    Windows 7:
    Control Panel > Appearance and Personalization > Display > Change display settings > Advanced settings > Troubleshoot
    If this doesn't work, try playing with the update method settings. Set the UpdateMethod parameter (in VNC Server options, Expert tab) from 2, to 1. If this doesn't work, try setting it to 0.
    0 = Polling (Slower over low bandwidth, but will capture the entire framebuffer)
    1 = VNC Hooks (Fairly efficient "all-round" update method, but may miss certain GDI hooks in the framebuffer)
    2 = VNC Mirror Driver (Extremely fast/efficient capture method, but may miss certain video/3D related events).
    * The VNC Mirror Driver should be in use where possible, to provide better performance.
    * For times when a 3D application/video cannot be remoted, reverting to VNC Hooks will most likely provide updates, but the performance will be degraded.
    AMX Touchpanel
    There are some further settings that need to be changed to support AMX Touchpanel:
    Go to VNC Viewer -> Options -> "Adapt to network speed" and uncheck the tickbox.
    Then the "ColourLevel" needs to be changed. Go to Expert tab -> ColourLevel and change the default value to "rgb565".
    Still not working?
    If the above workarounds don't work for you, try simply either minimising the application that is causing you problems, or if it's running in full screen mode, run it in windowed mode. Reconnecting may be required.
How to monitor internet brwosing on WLAN & LAN
Install free vnc server on the computer you wish to monitor and vnc viewer on your own computer.
There are various flavours of the vnc programme and most are free to download. try cnet.com
Mar 04, 2014 | Computers & Internet
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
How to share a desktop
If you need to sharedesktop inside lan means you can use vnc viewer,tight vnc viewer
If you need to share the desktop through internet you can use teamviewer,logmein
You can also share the desktop by using chat software in some chat clients you can see share my desktop option
Mar 04, 2010 | Dell Dimension 1100 PC Desktop
We have a Savin 9945DPE that needed a new hard drive. We run a windows based Small Business Exchange Server 2003 and XP operating system on clients. Anyway after the new hard drive was installed we cannot...
do not use the dhcp for the ip for the printer. set it to static. make sure the first pc you set the driver from is set to local printer as the default. make these changes and let me know.
Jan 02, 2010 | Ricoh Aficio 450e Laser Printer
Port forward VNC server. Not able to connect vnc viwer from external network.
What VNC product are you using? RealVNC? TightVNC? UltraVNC? The VNC software you installed will have a port# assigned to it by default (probably 5900) which can be configured. Find out what that is and forward that port# to the IP of your VNC "server." That should do it.
(don't fogot about any software firewalls on the VNC "server" machine)
Dec 07, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
How to remote one computer to another in networking
download real vnc on both pcs use viewer to connect to pc running vnc server
Apr 03, 2009 | Computers & Internet
Windows xp remote desctop (tweaked) , how to overcome problem with limit of 3 persons logged on windows xp in the same time?
hi,
As if you are aware, Windows XP is *NOT* a server operating system, so, any time, only *one* user will be allowed to log in *interactively*.
You need to use VNC software if you want to use your system by multiple users at the same time.
But, session will remain interactive for only one user at a time.
By *interactive* i mean, only one user at a time can be logged in, if multiple users are logging in using VNC or any other Utility software, they will be sharing the same session/desktop.
Thanks and regards.
Mar 10, 2009 | Microsoft Windows XP Professional
Windows XP Does Not Allow Inbound/Outbound Connections
some malware has restricted access to administrative tasks,
try to download SPYBOT
check your system +-20 min
Nov 26, 2008 | Dell Microsoft Windows XP Home Edition
Problem with Remote Desktop
On an XP client you can only have one person logged at a time.  This is different on M$ Sever 2000 and up where you can have multiple log ons.  There no way to do this this with M$ RD - However you can achive what you are after by using  third party RD software such as Real VNC There is a free client (which i use to access mac's & win machines) or if you prefer ssh etc it is quite cheap for the full version.
Oct 18, 2007 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
137 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
