Question about NAD T754 Receiver
Trying to connect the nad t754 to a new samsung smart tv. Using a Motorola cable DVR. Get sound to CDs and fm but not TV. Was set up previously on a samsung through a cable box but was not a smart tv
  • 4 Answers
SOURCE: NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for video...ie: s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Posted on May 07, 2009
chrisreitano
  • 85 Answers
SOURCE: I am trying to hook up my home theater system
marvidson,
With the NAD model that you have and its lack of component or HMDI switching, the only way is to connect your system, sort of, backwards.
The only way to do it is to connect your digital cable box and blueray player directly to the tv, then the audio output from the tv to one of the video inputs on the NAD. The NAD has digital coaxial and toslink inputs so if your tv has one of them as an output, that would give you the best sound to the NAD. If your tv does not have either of those outputs, then you will be limited to the composite outputs (red and white) but that will still give you good sound.
Also, depending on the digital output to input configuration, you could possible find a converter online.
-Chris
Posted on Feb 28, 2010
  • 41 Answers
SOURCE: I just bought and set
Check that the speaker A/B switch is engaged properly. Also, is there a tape monitor active that should be disengaged?
Posted on Jan 06, 2011
mikeywaf
  • 346 Answers
SOURCE: I have an NAD T755.
Hi - Not a flash of brilliance I know, but have you switched physically the HDMI cables between the PS3 and STB before connecting to the NAD?
Also - You might try (if you have them) a set of component cables from the STB to the receiver to try and see if the cable box may be having having difficulty with your NAD.
If you can let me know the results of cables switching I'd appreciate it. On a personal note I both love and hate HDMI, having had similar problems 8^)
Good Luck
Posted on Mar 26, 2011
  • 961 Answers
SOURCE: Have a HD cable set-top
If this is your system;
http://www1.epinions.com/specs/pr-NAD_T742_5_1_Channel_Home_Audio_Receiver
It has two "digital optical" inputs for sound. The video doesn't need to pass through the receiver so, your HD components, box and Bluray player, should hook to TV directly then, providing your TV has digital optical out, you could run your audio out of the TV from a digital optical out, to receiver. This would allow you to select your video through your TV's menu and the sound would come through the receiver through the one input. You can pass your video through the receiver but, it doesn't have the best outputs to handle it. You also may notice lags beteween the audio and video if you go this route.
Posted on May 22, 2011
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
I need to know what model of a Motorola DVR is compatible with my receiver. What model can connect DIRECTLY from it's audio output to the audio input of my STA-795 Optimus Digital receiver (not through the...
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
Apr 21, 2011 | Optimus STA-795 Receiver
I'm trying to connect my dvd recorder to my Motorola dtc6400 DVR. I can record picture but not sound because there is only one set of RCA audio outputs on the DVR and they go to the HDTV. There is also...
See if your TV has an audio out socket at the back. If so connect this aodio out to the DVR to record the sound . If not buy a pair of ( one for Left channel and the other for Right channel ) one is to two Y connector and plug the jack to the DVR and connect the split ends to the TV and Motorola DVR. That way you will have sound going to TV & DVR
Mar 31, 2011 | Arris DCT6200 DTV Receiver
Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Aug 05, 2008 | Televison & Video
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
NAD T754 Receiver Logo
119 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
