How can I jumper down my "Toshiba dt01aca100" hard drive to "SATA I" in order to be recognized by my ASUS p4v8x-x mother board?
Kidyubyub
  • 143 Answers
SOURCE: Hard Drives -ATA and SATA
Yes, they can coexist.
Posted on May 18, 2008
  • 32 Answers
SOURCE: Sata hard disk drive on asus p4v8x-x motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
Posted on Jan 20, 2009
I faced the same problem with this mobo...I needed a SATA HDD for data storage, while the system was on a PATA HDD. The drive was a WDC 1600 AAJS, a SATA2 compatible one and to make it work, I had to jumper it down to SATA 1. (5-6 pins as I remember) I also set my BIOS the way it was described above. (ACPI 2-disable, APIC-disable) Then at restart, BIOS recognized and listed it. Ubuntu 9.04 and 9.10 works with it seamlessly.
As I ran through several sites, I saw that old power supplies can also cause similar problem,. If you connect a SATA drive with 3.3V needs, since old PSUs can feed only with molex-SATA power converter cable and that does not provide 3.3V.
mobo:P4V8X-X, BIOS ver.:1008
Posted on Nov 01, 2009
bhagyavichar
  • 414 Answers
SOURCE: is a 80gig western digital hard drive compatableto
hope u r a professional..
yes, itz compatible..
howevr, for all pata ide drives..remember the master(MA or MS) jumper is always in a vertical position along or just beside the ide cable port/pata port..while the slave is either 'open-all' or just beside..
there's no such jumper to b fixed on the main/mother board..
for details contact system admin/vendor....
Posted on Nov 10, 2009
puertobori
  • 7733 Answers
SOURCE: sata hard drive not support
The hardware of your system need more hardware capacity and some slots on the mobo for the sata cable.
Posted on May 01, 2012
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
SATA HDD is not detceted properly
As far as I can remember, the VIA VT8237R southbridge used on this board has a bug, causing it not to recognize SATA II drives.
You may be able to configure your hard drive to use the slower SATA 150 mode (1.5 GBit/s or 150MB/s) by setting a jumper on the drive. Unfortunately, this is not supported by all models - check the jumper description on the drive.
If the drive doesn't offer this feature, you might consider adding a SATA controller like this one (you may be able to find better and cheaper controller cards at your local computer store).
Mar 22, 2010 | ASUS K8V-MX Motherboard
New sata harddisk not detected
The mother boards from that time you had to install the RAID drivers to use SATA drives. The drive disc which came with the mother board should have the drive, but I would suggest going to ASUS's web site and download the latest drivers. Click the link below, Select which OS (Operating System) you are using, Next click the little + box next to "IDE" and the drivers needed will be listed.
http://www.asus.com/product.aspx?P_ID=xCBogxJhh6yWBQRi&content=download
Jan 26, 2010 | ASUS P4V8X-MX Motherboard
Jan 20, 2009 | Computers & Internet
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
Aug 08, 2008 | Intel Motherboard
Same problem, but not solved
Matias,
Please remove the jumper on the SATA drive. Boot to the bios & see if the SATA drive is listed. If it is you're good. If this is the first SATA you have tried in the Asus board & my suggestion also failed to show the SATA drive you are left with two options.
One the SATA drive is defective or the SATA motherboard controller is bad. You can call Asus tech M-F 8:00AM to 5:00PM EDT. At 1-812-282-2787, there is little wait time when calling Asus tech. Asus does not charge you for calling them.
Mike
Jul 13, 2008 | ASUS P4V8X-X Motherboard
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Hdd
your board may support sata however it may support sata 1 not 2 and your hdd may be a sata 2 one..so all you have to do is to check the hdd jumper and set it on sata 1 and also check the bios for the right settings to be made...
good luck
bye
Feb 09, 2008 | ASUS P4V8X-X Motherboard
i think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
Jan 28, 2008 | ASUS P4V8X-X Motherboard
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
