Question about SNK Fratelli Onofri Royal Chiantishire FRRYC905S Dual Fuel Range
Fratelli onofri model OV1 608 broken door - SNK Fratelli Onofri Royal Chiantishire FRRYC905S Dual Fuel Range
2 Suggested Answers
  • 4736 Answers
SOURCE: i just installed a new
The first thing to check is the required, inline gas shutoff valve. Is it fully ON. I know it had to be turned off to complete the conversion to LP Gas.Secondly, if you had a convertible gas regulator, was the little pin reinstalled in the proper direction. If you didn't have a convertible gas regulator, are you sure the one you changed to, is in fact for LP Gas? If not, there would be little to no gas flow. As Natural gas requires a different pressure than Propane Gas.
In addition, there may be air in the line, from when the gas was turned OFF. That air will need to be purged from the line. You can do this, by trying to continually light a burner. If after 5 minutes there's no gas. The problem may lie in an obstruction in the gas line. Check for any trash (pieces of Teflon tape, Pipe Joint Compound, etc) in the line to the cook top.
Also, if you have the equipment to do so. Check the water column inch after the regulator. It should be 11 to 13 water column inches for Propane & 7 for Natural Gas. If you don't have the equipment, contact your Propane Provider as they do have it.
Hope this helped you to further troubleshoot and solve the problem Please let me know. Thanks.
Posted on Jun 13, 2011
Has anyone had any luck finding replacement gasket? I have a Italian-made Fratelli Onofri 36"range (FREV 905S) and need to replace the oven gasket, which is broken.
Hello, Camr -
You did not state where you reside (what country.) Knowing that information will help in providing you the best source for a replacement oven door gasket.
In case you reside in the United Kingdom, you will find a replacement gasket here:
https://www.espares.co.uk/search/ma2925pt1602/cookers-and-hobs/seals/fratelli-onofri
Best wishes.
Mar 13, 2018 | Kitchen Ranges
I need a conversion kit natural gas to propane for a Fratelli Onofri range. Anyone handle parts for these in the States?
try your local propane dealer .some newer stoves do not require a kit ,as they have adjustable orifices
Aug 13, 2015 | Kitchen Ranges
Royal chiantishire buzzing how to fix
I have the same buzzing ticking clock sound much too noisy. Can't find a way to get to the clock
Mar 19, 2014 | SNK Fratelli Onofri Royal Chiantishire...
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door wont shut
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Miele Dishwashers
Handle loose on fratelli onofri royal chiantishire range
take off the whole door including the glass and possibly the lower shelf watch out for screws inside you can fix
Jun 19, 2012 | SNK Fratelli Onofri Royal Chiantishire...
SNK Fratelli Evolution FREV905S-S Stainless Steel electonic clock and timer running slowly
This is from Tim at JMAppliances 2/24/2011:
These clocks are built to operate at 50 cycles(Europe) and 60 cycles(USA) and this is controlled by the audible alarm setting. The clock has to be set on the loudest (highest tone) alarm for the clock to operate at the correct setting. You control the loudness of the alarm by pushing the minus button (second from the right) repeatedly until you here the loudest (highest) sounding tone. Leave it at that setting and the clock will work fine.
Hope this helps
Feb 09, 2010 | SNK Fratelli Evolution FREV905S-S ...
SNK Fratelli Onofri Royal Chiantishire FRRYC905S  Dual Fuel  Range Logo
23 people viewed this question
Top SNK Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a SNK Kitchen Range Expert? Answer questions, earn points and help others
