Question about Garmin Dezl 560lmt GPS Receiver
Garmin 560LMT freezing - Garmin Dezl 560lmt GPS Receiver
Start
Try plugging into a computer and see what it does then.
Apr 20, 2014 | Garmin Dezl 560lmt GPS Receiver
I need to get hgv software onto my garmin
HGV software cannot be loaded to the Garmin.
I would recommend getting the Garmin Dezl 560LMT trucking GPS as it comes loaded with truck friendly features.
http://www.gpscity.com/garmin-dezl-560lmt.html
Feb 08, 2012 | Garmin nuvi 200W Car GPS Receiver
Hi - I own a Garmin Nuvi 260w. Is it possible to use the SD card to download a trucker navigation road map and upload this to my Garmin Nuvi 260w? Thanks for your response.
It is possible as long as the map is Garmin compatible.
However even with a trucker navigation map installed, the nuvi 260w will not function as a trucking GPS as the routing and IQ of the nuvi 260w does not have the capability to operate in this manner.
The nuvi 260w does not have a trucking mode to allow for the input of specific truck information like truck and trailer length and gross vehicle weight to use as factors on determining the best route for the specific truck/trailer combination.
I would recommend using a GPS specifically designed for trucking like the Garmin Dezl.
Sep 10, 2011 | Garmin nuvi 260W GPS Receiver
Garmin is not working. Nothing appears on screen.
A few tests to see if the internal processor is running - assuming the internal battery is charged.
1) Connect the car charger to the Garmin Dezl - the screen should light up with a text a while its charging the internal battery.
2) Connect a PC / Mac with the Garmin Dezl - the screen lights up with a computer icon on the bottom of the screen.
3) Hold the power button of the Dezl for at least 20 seconds - the Dezl should restart.
4) Master reset to factory defaults : hold the right bottom corner of the screen for at least 20 seconds while pressing the power on button once. A question should appear.
If none of the above produces any result - contact Garmin support - the Dezl is not working properly.
More hands-on details for the Garmin Dezl 560.
Jul 06, 2011 | Garmin Dezl 560lmt GPS Receiver
Is there any software to make my 1370t trucker friendly
Unfortunately there is no additional software you can add to preform that function, Garmin makes 2 different unit targeted specifically towards truckers they would be the nuvi 465LMT and the dezl 560LMT. Both of these unit can be found at either www.gpscity.ca or www.gpscity.com.
Hope this helps!
Apr 11, 2011 | Garmin 1370T 4.4 in. Car GPS Receiver
Garmin freezes up on the first screen (which says garmin).
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin sometimes freezes
Try update the unit with the latest firmware by using WebUpdater from Garmin.
Oct 28, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 200w map freezing problems
Not being able to start up and freezing up are signs that the system software or firmware of your Nuvi has become corrupt.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
I hope that helps.
Jul 17, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Dezl 560lmt GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
