Question about Tablets & eReaders
A friend of mine dropped her Polaroid PMID709 and the tablet opened up a little. She just popped the case back together and never thought of it again. About a week later her tablet stop taking a charge unless u push down on the plug so she is sending off for a new wall charger. I went to know if something could have been damaged when it was dropped and if it is nothing more then a paper weight now.
    New Friend:
    Problem Solver:
  • 6 Answers
I wont to know how I can unlock the I pad
Posted on Oct 16, 2013
SOURCE: new battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
Posted on Feb 01, 2010
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
  • 1288 Answers
SOURCE: My Toshiba Portege M200 just
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Posted on Mar 23, 2011
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
  • 5 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
online shopping
Posted on Mar 08, 2012
P1000 10.1 polaroid tablet. How can I get keyboard to work?
Hi they r cheep to buy on E/BAY APROX $23. THIS WOULD B THE BEST WAY TO FIND OUT IF IT IS THE KEYBOARD OR YOURE TABET THAT IS AT FAULT CHEERS
Mar 07, 2016 | Polaroid Tablets & eReaders
How do i reset internet tablet
Hi, I've had 2 of these before i got rid of them. I had to get my friend whose great with computers go in from his pc to open mine, so i could wipe the data before returning. If you call polaroid.com they can give you the steps to do this. Unfortunately it is fried, it may work awile after you get it open, but mine didn't. Hope this helps . I also found out this tablet is a starter tablet like something you buy for your kids 1st tablet. Good luck. JMF
Jul 18, 2014 | Polaroid 8-Inch Android 4.0 4 GB Internet...
POLAROID TABLET PMID709 WILL NOT CHARGE
How old is tablet , maybe new battery is needed ???? Is there power at the wall plug your using ???? Sometimes it's as easy as the plug , !!M the charger your using May be bad , do you know how to use a voltage meter to test if there s power coming from it to your tablet ?? More info is needed on this ??
Dec 01, 2013 | Polaroid Tablets & eReaders
Nexus 7 screen broken and back slightly popped
It sounds like the device is completely broken after dropping it. You may find a local repair shop or a shop online to fix the device, but it may be cheaper to replace it with a new one.
Hope that helps!
Feb 24, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
I need a digitizer screen replacement for my polaroid tablet ice cream sandwich
This is not a solution but more of a description if I am correct. I am working on a Polaroid PMID705 tablet for a friend and the capacitive touch screen cable is torn apart due to a kid dropping it. If I am correct I do believe that the person is asking where they may be able to get a replacement screen.
Jan 15, 2013 | Polaroid Tablet Computer PMID701
How to remove battery from zeepad 7.0 tablet
Hi open a zeepad is very easy, you need apply some pressure over the case and the screen. I recently open my sons tablets. regards.
Oct 29, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Tablets & eReaders Logo
48 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
