Question about Challenger Products Heat Lamps, Food Warmers and Accessories Challenger Rice Cooker/Warmer
I have two 30 cup Challenger rice cookers and I need to replace the rubber mats that go in the bottom of the cooker pot. Where can I find these mats?
Ecj-s35 replacement pot
I have a ECJ S35S rice cooker with like a new inner pot but is not working and needs parts :(
May 20, 2012 | Sanyo ECJ-S35 3.5-Cup Rice Cooker
Does steam tray/lid go on top or bottom of rice cooker?
The steam tray as you call it goes on the inside bottom of the cooker. It's purpose is to keep the cooking rice separated from the heating element during the steaming process. The basic measurement is 2 parts water to 1 part rice. Add a quarter cup more water for brown rice. The automatic shut-off won't turn off until the water is gone. It's magic! Cleaning; soak the cook pot and perforated plate to remove rice goo DO NOT USE STEEL WOOL PADS or abrasive cleanser. I use a nylon dish cleaning brush to remove the stuck on brown material.
Mar 14, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Need a replacement pot for national sr-mm10n 5.5 cup
I just ordered a replacement pan for the SR-LA10N rice cooker from www.PartStore.com. (They also carry the lid cap, and the measuring cup!)
Mar 06, 2010 | Panasonic SR-LA10N 5.5-Cup Rice Cooker
Cooker pop too fast the rice is not done why?
If this is a new rice cooker this shouldn't happen.
Maybe someone bumped the rice cooker while in cooking cycle.
If this is a rice cooker 2yrs or older, you should replace the Thermal Sensing Unit.
Feb 06, 2010 | Rinnai RER-55AS 55-Cup Rice Cooker
Sensor problem turning off during cooking
If this is a new rice cooker first try cleaning the thermal sensing unit by scrubbing any build up with a green brillo like scrubber, also clean the bottom of the rice pot where it contacts the thermal sensing unit.
If this doesn't work and your rice cooker is 1 to 2 years old replace the thermal sensing unit.
Jan 19, 2010 | Rinnai RER-55AS 55-Cup Rice Cooker
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Hitachi RD6106 10-Cup Rice Cooker
The Hitachi has notches on the inside of the pot. You put your rice in the pot and than start adding water until your water level reaches the notch labeled 7. Remember that the rice has to be inside the pot when you start adding water so that you will have the correct amount of water for the rice you're cooking. It doesn't work the other way around. Rice in pot than add water. But usually the average cup that comes with these rice cookers only holds 3/4 of a cup when you fill them to the top.
Jul 09, 2008 | Hitachi RD6106 10-Cup Rice Cooker
Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
Mar 19, 2008 | Salton RA3 3-Cup Rice Cooker
Sanyo ECJ-AC4E 4-Cup Rice Cooker
I need a replacement pot for the Sanyo rice cooker ECJ-AC4E. If the pot is in excellent condition, do you want to sell it?
Jun 13, 2007 | Sanyo ECJ-AC4E 4-Cup Rice Cooker
Challenger Products Heat Lamps, Food Warmers and Accessories Challenger Rice Cooker/Warmer Logo
214 people viewed this question
Top Challenger Products Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Challenger Products Kitchen Appliances - Other Expert? Answer questions, earn points and help others
