Question about Boating
My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro switch? 45 lbs thirst freshwater motor
    Champion:
    New Friend:
  • 227 Answers
Do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Posted on Dec 25, 2013
  • 8 Answers
SOURCE: Converting From 12/24 to Starght 24 Volt
The batteries must be connected in SERIES. The method described is proper, but the name of the method is wrong.
On the female plug for the motor on the boat, if you have the wiring for TWO separate batteries coming to the plug, the male plug must have a jumper in it. To find out, disconnect the batteries one at a time and voltage check to see if there are two separate battery systems there. There probably are. If so, the series circuit is provided for in the male plug by the jumper and not in the back of the boat where the batteries must be wired independent of each other.
Posted on Nov 28, 2008
SOURCE: Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
Posted on Aug 09, 2009
  • 53 Answers
SOURCE: I just bought a 74 lb Minn Kota trolling motor
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Posted on Nov 04, 2009
SOURCE: Wiring diagram for Die Hard 28 lbs thrust trolling motor
model #217592860
Posted on Nov 09, 2009
  • 4 Answers
SOURCE: diagram of 36 volt hookup for trolling motor
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Posted on Nov 12, 2009
Why does my motor guide 50 trolling motor fuse
It depends on how much current the trolling motor is supposed to draw when set to 5. If it's more than 40 amps, then you need a larger breaker. If it isn't more than 40 amps, then your current 40 amp breaker is weak and needs to be replaced.
May 13, 2014 | MotorGuide Electrical Supplies
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
How to find the fuse box on a 2008 lowe stinger 195 boat
Depending on the item in question, trolling motor, for example, there is a fused/breaker directly running off positive side of battery. Looks like a pill box or match box. Several people have had their trolling motors quit working and this is usually the culprit. Much of the fusing runs directly of hot wire from batter to item in question. However, I will paste a URL here for you. http://www.marine-electrical.com/resourcelibrary/wiringdiagrams2.aspx
Oct 25, 2012 | Cars & Trucks
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
How to attach leads to batteries
This is what they call a series connection. The two 12 volt batterys are wired together in a series to make one 24 volt battery. The positive wire or red from your trolling motor goes to the positive post on battery 1. The negative lead from trolling motor goes to the negative post on battery 2 then there is a short wire that goes from negative on battery one to positive on battery 2. NOW GET THAT HOOKED UP AND GET IN THE BASS.
Nov 29, 2009 | Electrical Supplies
I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
New MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
May 23, 2009 | MotorGuide Electrical Supplies
Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Jan 18, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Boating Logo
157 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
