I tried to install non-genuine ink cartridges into my Canon MG5150 and now it wont work. It comes up with "B200 printer error unplug and contact service centre" How can i get it working again?
    Sergeant:
  • 216 Answers
I am sorry to hear that you are having problems with this ink cartridge.
There may be several reasons for the problem.
Lets start out by installing the old ink cartridge if you have it. If you have the old cartidge and reinstall it and don't get the error than I would suggest purchasing another replacment cartridge. IF you still get the error with the old ink cartridge than you will need to send your printer off for service. ( i suggest purchasing a new printer before paying for service.)
Also most of the printer companies have install RFID chips in ink cartridges, So unless its a factory ink cartridge it may note actually work in your printer.
Canon, Lexmark, and HP all use RFID ( radio frequency identification) This prevents you from purchasing cheaper cartridges so you are left with either refilling you old cartridges or purchasing OE ( original Equipment).
I hope this helps you with your problem, feel fee to let me know if there is more I can do for you.
Posted on Oct 16, 2013
The Machine
  • 788 Answers
SOURCE: Printer wont recognize new or old cartridge
Use a Q-Tip and some clean water to clean the contacts behind the cartridge in the printer and on the cartridge itself. Then use a pencil with a clean eraser to polish the contacts. Be careful not to touch the part where the ink comes out of the cartridge.
Also, are you using Canon ink or third party?
Posted on Jan 11, 2008
comaire2004
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Posted on May 12, 2008
SOURCE: RECOGNITION OF GENUINE CANON INK CARTRIDGE
most probably has been damaged.
ink cartrigde is damaged due to followin causes--
1. over heating  of head due to bulk printing
2. mishandling the cartridge.
3. repeated refillings
try this if you want to use this cartrigde again, it may work
1.  clean the golden contact points with isopropyl alcohol of cartrigde as well as the cartridge holder
2. remove cartrigde and install again after some days
possibility of fault in printer is minimal,
Posted on Jul 02, 2009
cns assoc
  • 677 Answers
SOURCE: i am using non genuine ink cartridges in my epsom
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem. Maybe you were able before, but not now.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 04, 2010
  • 232 Answers
SOURCE: ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Posted on Apr 11, 2010
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
My printer was out of ink I put new ink in and now it say printer error unplug an contact service center b 200. any way I can trouble shoot it myself I really need to print these important papers now
How to Fix Canon Pixma Support Code B200 Error Message
? 3:06
https://www.youtube.com/watch?v=jxhkgrozauY
Mar 5, 2014 - Uploaded by Refresh Cartridges
The Canon Pixma "Support Code B200" error message may also be accompanied by text stating "Contact ..
Nov 17, 2015 | Office Equipment & Supplies
Shows code b200
Hi Joseph,
Regarding your Pixma MX882 printer inquiry (Canon 225/226 ink cartridges) and B200 error message, most likely the built-in PRINTHEAD is reaching it's end-of-life and may need to be replaced with a new one. Typically, the average printhead only produces ~4000 to 5000 pages before it electrically fails.
For information on PRINTHEAD failures, please refer to our support page: http://inkjet411.com/?page_id=2934
However, let's run thru the full checklist to screen out additional variables:
Canon B200 Error, Troubleshooting:
Replace ink cartridges if they are empty:
At the risk of stating the obvious (frequently not so obvious in the heat of the moment), find out if the ink cartridges are empty. When in doubt, try a new Canon original ink cartridge to see if this corrects the error.
A data cable of print head is open:
Did you just replace an ink cartridge? Perhaps you shifted a data cable to the print head.
Replace PRINTHEAD if it is damaged. Refer to Canon.com for replacement part.
Turn off the printer for some time
In other troubleshooting tips we have advised any inkjet printer not seeing regular usage to run a test print page. If you are making heavy usage of a Canon inkjet printer, consider giving it a break. This will avoid saturating the printhead with heat, prolonging useful service life.
Update the printer driver:
If you have followed all this with no success, from the printer menu (not computer) push the buttons to get a demo or test page. If everything is ok when you do this, however you get the service error code B200 when you try to produce something productive, odds are good, the print driver the computer is using has gone south (corrupt). When printing on a network, a corrupt printer driver can spread like an unwanted virus. Depending on the network, a driver that has gone rogue may be seen as an updated driver, which network will 'helpfully spread' as an update.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
To find an authorized ink center refill location near you (i.e. Costco, Frys, Micro Center, Best Buy, Sams or University bookstore location), using our premium quality & certified Canon inks, please visit: http://inkjet411.com/?page_id=3472
Please let us know if you have any questions regarding the technical information provided herein. For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Inkjet411 Team Representative
May 17, 2014 | Canon MX882 All-In-One InkJet Printer
Canon pixma mp560 printer error b200
Leave the cover open, turn off, before it off, hold the reset & Start (color) until it completely off, then turn it back on. it works for me, good luck folks
Jun 29, 2012 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
What is error B200 when attempting to power up
http://www.printerdiary.com/2011/09/canon-error-b200-how-to-fix-it.html
Error B200 on Canon printers is a print head error. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Mar 24, 2012 | Office Equipment & Supplies
What is error B200 on Canon MX850?
The B200 error is a Voltage High Error. I read that you should try using a different power outlet and see if that works and if that doesn't work try cleaning the print head:
  1. Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
    • Unplug the printer
    • Manually slide the carriage over until you can get the ink cartridges out.
  2. Remove the ink cartridges from the print head.
  3. Use cotton swabs dipped in hot water or a mix of hot water and alcohol to thoroughly clean the print head.
  4. Repeat this until there is no ink residue coming off on the cotton swab
  5. Allow to dry and replace the cartridges
  6. Try to print something
If it doesn't fix it then the board inside of the printer is faulty and you will have to replace the printer
Thanks. -Sa_Les_Ski
Feb 28, 2011 | Canon PIXMA MX850 multifunction InkJet...
B 200 error canon pixma mg5150
B200 Printer error has occurred. Unplug the power cord and contact the service center. The printer has an issue that can only be resolved by the service center.
Jan 24, 2011 | Office Equipment & Supplies
Canon Mx 300 Printer wont work
Error Code [1401] or CHECK INK U051 = cartridge may not install properly or using non-genuine cartridges, refilled cartridges or faulty cartridges.
May 27, 2010 | Canon MX300 Office All-In-One Printer
Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
Mar 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
46 people viewed this question
jasbo
jasbo
