Question about HP Officejet 5610 All-In-One InkJet Printer
I HAVE A HP ALL IN ONE OFFICE JET 5610 AND A DELL COMPUTER . I AM UNABLE TO PRINT A FULL PAGE . THE RIGHT HAND MARGIN IS MISSING THE LAST TWO OR THREE WORDS . THANKS . I AM NOT COMPUTER BLESSED
Nitrotrike
  • 589 Answers
SOURCE: mac leopard
Did you download and install the Mac drivers from HP?
If not, here they are:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&cc=us&dlc=en&product=441125&lang=en
The first download under the "software" category includes software and drivers that cover 10.5 Leopard.
Posted on Feb 09, 2008
  • 66 Answers
SOURCE: Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Posted on Nov 07, 2008
  • 35 Answers
SOURCE: I want to set my HP office jet 5610 on to auto answer
You must set Auto Answer to on. More info can be found on page 68 of the user guide found here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=441125&
Posted on Nov 11, 2008
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Posted on Nov 12, 2008
SOURCE: hp office jet 5610- can't print
Please check for any paper jam inside the machine, Phone off hook message is becoz if you use the same phone line for fax and telephone, thats normal. Follow the steps below,,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 23, 2009
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
HP OfficeJet 5610 leaves large blank areas
can be a problem on the thermal roller, have you try to clean print head first..?
Aug 30, 2008 | HP Officejet 5610 All-In-One InkJet...
It will not print Word documents. it pulls a blank piece of paper through. It will print in notepad
there is something wrong with your Word printer setup. Go to Word, then from the File menu select the Print option and when the print window opens see if the HP deskjet is selected as default printer. Then, in the upper right quadrant theres a button called Advanced Settings, or Prefferences (depending on your Word version). Click that button and check to see if the HP printer is set as On Line, and is set to print odd and even pages. Also, check the margins of the paper. Ink Jet printers cant print over the full page, there's always a need of some margin on each side of the paper, so you'll need to set the margins from all sides on at least 0.5 inches
Jan 18, 2011 | HP Deskjet F2210 InkJet Printer
Printing Legal size brochure (landscape) that gets cut off
readjust the margins in the printer page set up just before printing
Sep 08, 2017 | HP Inkjet 1200D Printer
I want to print a configiration page from my hp office jet 5610 all in one printer
If you want a snapshot of how the printer is configured and a quick self test, to the following from the front panel of the 5610.
1. hit the "Setup" button.
2. hit the right arrow to "Print Reports"
3. hit the "ok" button
4. hit the right arrow to "Self Test"
5. hit the "ok" button
The printer will then print a report that tells you the series and model number as well as the serial number, Service ID, LIU type, Country/Region, The active I/O connection, all of your cartridge alignment settings then display color bands for all your cartridges. It also tells how many pages your printer has printed (I am up to 2,068 on the cartridges that I reload myself) as well as the firmware version.
Good luck and hope this helps. -Dan
Oct 10, 2009 | HP Officejet 5610 All-In-One InkJet...
I am not able to print the portion from exactly start of the page of ms word document, why? Not able to show it in print preview??
Hello and Welcome to FixYa!
The portion within the Margins can only be printed, lessen the top margin at bit.
I remember the top margin for default is 1', change it to 0.5' or 0.6'
In Office < 2007 (Margins are in File > Page Setup)
In Office 2007 (Margins are in Page Layout > Margins > Set it to Narrow)
Note: If you printer is non-Laser (I mean if it is Ink-Jet) Do not make the margins too less, the printer won't be able to print it.
Sep 27, 2009 | Microsoft Office Word 2007 Upgrade Version...
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
I lost my cd for my printer adn need to install it on my dell pc
Go to this Link :- http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us
Choose and Click on Operating system
On next Page click on :- » HP Full Feature Software and Drivers
on Next Page Click on Install or Download
If you click on Download then save it on desktop and once the Download is compleated then Double click and Run it,
It will Install your Printer.
Oct 30, 2008 | HP Officejet 5610 All-In-One InkJet...
How do i print edge to edge using the G85 Office Jet all in one?
The G85 does not support edge to edge printing, it requires a top margin of 0.08:, a bottom margin of 0.46" and side margins of 0.25".
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
