Question about Whirlpool duet Washing Machines
I have a whirlpool duet (wfw94hexx) and washed a heavy load and now have a long drainage error (F01E09) and have also had a SUDS error. I have taken apart the machine, cleaned out the drain trap (had a couple of quarters, pebbles), drain hose, and checked most of the electrical plugs. I am not able to get it into diagnostics mode. Do you think that I need to replace the drain or control panel?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Whirlpool Expert
  • 154 Answers
Replace the pump first, empellers could be broken and not pumping water out fast enough
Posted on Nov 03, 2013
  • 1 more comment
  • Rodney Owen Nov 24, 2013
    I have a Whirlpool Duet Washer I bought new a few years ago, after some sand got into our water lines from a well pump issue we have had several issues with the washer. The latest is that even while the unit is turned off the cold water flows rapidly into the washer causing an eventual overflow. Does that sound like a faulty pressure switch to you? I have already replaced the pump solenoid on the unit.
  • ROB CHRISTIAN
    ROB CHRISTIAN Nov 24, 2013
    the sand has damaged the water inlet valves (hot and cold), replace them with new
    I did that once, would it be faulty again? Would anything else cause the water to flow uncommanded and constantly with the power to the unit off?
  • 249 Answers
SOURCE: Duet Washing Machine model ghw9100lw1 FH ERROR CODE
you should here a humming noise, just before water comes in .do you?close eire let me know.
Posted on Dec 07, 2007
SOURCE: Whirlpool Duet Sport Washer will not drain - F-21 error
Perfect! Yes, they aer 1/4" 6pt screws. I didn't have to lift my washer, but the previous tech had put in 1 screw crooked, so that was FUN! I had cut out an opening on an old cracked tote and was able to hold all the water as long as I transferred some to a bunch of tupperware. Make sure you line up the upper mark on the white drain plug before putting back in. The tote was getting overloaded and I didn't notice the alignment marks until after having some water overflow. Just a heads-up if anyone has an emergency and HAS to get the plug back in in a hurry.
I found:
Wife's Victoria's Secret panties
2 dimes
4 pennies
some legos
a metal nut
pencil eraser
wall anchor
some legos
Posted on Jun 30, 2008
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
SOURCE: Suds error then F35 at the beginning of the was cycle
I too have a Whirlpool Duet Steam Washer that is just 13 months old and had this same problem. If you have searched the internet about this you have probably noticed that there are quite a few people out there with the same problem. It is the analog pressure sensor switch. I was lucky enough to find one that I received last Friday. It is an easy fix if you're not afraid to attempt it yourself.....the problem you will probably have is finding the part. I searched several parts stores and everyone had them on a 3 to 4 week backorder, but I got lucky and found ONE in stock. If you remove the top of the washer by removing the 3 screws that hold it on in the back and sliding it off, you can see the pressure switch on the right/rear side of the washer. To remove the switch you have to remove the wires that plug into the switch and then turn the switch and pop it out of the side...the replacement just snaps back in the same way. My husband replaced the switch in probably less than 5 minutes and my washer is back up and running. Good luck finding the part (W10156252). I did write a letter to Whirlpool stating that this seems to be an on-going problem with these washers and that if they cannot reimburse the consumer in some way, the least they could do is make this part more readily accessible. Good luck.
Posted on Aug 04, 2009
SOURCE: f-21 error, washer not draining
I have had this code three separate times. The first time service man came and cleaned out the filter. This is behind the lower front panel and can be removed by hand. The cartridge style filter is located at the pump in the lower right of the unit. Have something available to catch the draining water as you loosen the filter. The second time I received this code I found a blockage in the drain hose at its bend. The third time no hose blockage, no filter clogging, but the pump impeller was jammed by an elastic strap that had made it through the filter. I removed it through the supply side of the pump seen after filter is removed.
Posted on Aug 13, 2009
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing ?Sud? error code on...
The error Sud is shown on the display due to Overdose of Detergent detected during the Wash Cycle in the washing machine.
In this problem check the MCU in the washing machine. The motor control unit senses a suds lock. Also check the Drain pump for any blockage or the heavy load in the washing machine. or over quantity of detergent is added to the machine and that is got blocked.
This will Help. Good Luck.
on Mar 11, 2010 | Washing Machines
S6 mean on my duet washer
1) this means overcurrent by the motor,the controller sense SUD detected. Indicating bad pump, or extra heavy load,excessive detergente, or SUDs. Press STOP/CANCEL for clear the display
God bless you
Jul 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Do you know what problem 5d or Sd means
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer (whirlpool duet) seems to cancel in the middle of load cycle. Most often the word "suds" is displayed. It is not the amount of detergent or the type because I use very little High Efficiency...
ERROR CODES
DISPLAY EXPLANATION AND RECOMMENDED PROCEDURE
Suds
6 - 7
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
Normal cycle without adding any detergent. This should clear the unit of the
excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
• Check/ Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool error SUB
To fix this problem do the following:
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code letters of sud came up during last spin cycle what is this and how do I fix it it will not finish spin cycle and clothes are heavy and drenched
This is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport machine will stop mid-cycle and all lights will flash and d5 will show on display
The display is actually reading "Sd", which is a Suds detect error. This is an indication that you have either used too much detergent, are using the wrong type of detergent, or you have an obstruction somewhere in the drainage system. The following link explains the error code and how to correct it:
There is a follow-on link included that explains the steps necessary to check the drain pump reservoir. Read through the information provided and let me know if you have any questions. I hope this helps you.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 error code on display board the Whirlpool Duet front load washer. Checked the drainage filter and line and it does drain just fine with the wet vac with no blockages noted. Does this sound like the...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Display panel reads SUDS
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Oct 28, 2006 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
