Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
I got my mower out the other day it did fine till I engaged the electric pto, it then died and I cant get it started since then. It is getting spark and is getting fuel. It act like it is flooded , I have cleaned the plugs and they have fuel on them. It will not even attempt to fire.
  • 2,113 Answers
If the fuel is set too high and the choke is on it is easy to flood it. The solution is to open the choke and keep the throttle low for a few turns to air dry the spark plugs then back to choke to start it again
Posted on Oct 16, 2013
  • 4 more comments
  • Jeff Childress
    Jeff Childress Oct 16, 2013
    I have turned choke off low throttle and cranked and cranked and no fire. I even took the fuel pump off and drained fuel and sprayed fuel in the carb and still no fire. I am not sure what to try next.
  • mikadot
    mikadot Oct 16, 2013
    The next step i would take is to make sure the magneto is not rusted shorting the laminations If so give it a quick cleaning. Test for a spark or hold the spark plug wire while cranking to see if there is a voltage if not then the coil on the magneto may need to be replaced
  • Jeff Childress
    Jeff Childress Oct 17, 2013
    Do u think the flywheel key broke and it is out of timing?
  • mikadot
    mikadot Oct 17, 2013
    the flywheel's purpose is to give the engine centrifugal force to help the engine get to the next stroke. It is also the easiest point to place a starter to start the engine. It has nothing to do with timing
  • Jeff Childress
    so what is your next idea?
  • mikadot
    If it is getting a spark... maybe the spark isn't strong enough. Make sure the magneto is not rusted (this is where it generates electricity) The magneto and coil pass each other The laminations of the magneto can't be rusted and shorting each other out. Also make sure the spark plug is screwed into a dry clean oilfree openning and that it is clean and gapped according to specs.
3 Suggested Answers
  • 152 Answers
SOURCE: non-starting CV 15 S
First what needs to be established is if it is a fuel or spark related issue.
1. test for a sparkissue: using a spark tester inserted in to the spark plug boot and clamped to bare metal on the engine. Engage the starter while inspecting for signs of spark.
2. Test for a fuel issue: using fuel in a stream style spray bottle outside and away from your building. remove the air filter assy. so as to open the throttle butterfly and spray a small amount of fuel into the carburetors air cylinder, close the throttle butterfly and attempt to start, listening for a reaction.
If the engine was retired for a season and was not prepped for storage properly, then my guess would be that unspent fuel that was left in the carburetor float bowl and may have varnished, thus clogging the carburetors ventries. If this is the case. a float bowl cleaning will resolve the issue.
Another typical issue are safety switches that are not engaged or faulty and can be found at one or all of these locations.
1.neutral safety switch found at the gear shift area
2.PTO drive lever area
3. Clutch/brake pedal switch
4. Operators seat switch, under the seat
All of which could cause the coil not to fire. Most of which are ground switches that could be unplugged to by-pass.
Possible issue could be a fouled or faulty spark plug.
I hope this helps.
Good luck
Aduz
Posted on Mar 22, 2009
  • 1388 Answers
SOURCE: just bought a used ferris
I would suspect low oil pressure or oil sending unit faulty. Low oil pressure is sometimes caused by foaming or watery oil (fuel in oil).
When starting the engine, oil alert is bypassed at the start switch. Easy to check. Just remove the sending unit wire at the engine. If engine continues to run, check condition of oil. If oil looks to be in good condition and correct amout, suspect faulty sending unit. If engine continues to cut-out due to spark, check all safety features that cut engine. This would include the brake, stearing arms if hydraulic, seat sensor, blade clutch and more. There is a lot of wiring in your unit that could be shorting coil. Wiring diagram would be nice but removing all kill wires from the coil would be easy test. There is an aftermarket oil pressure test kit available on the web. Google "Kohler oil pessue test kit", could be part # 25 76106-s not sure. This kit is installed by removing the oil filter and installing an adapter. Then read oil pressure of gauge. Good luck
Posted on Aug 26, 2011
What do I need to check to activate starter will not engage. Engine will start but dies when blades are engaged
If your mower runs fine, but dies when the blades are engaged, that has nothing at all to do with the starter - or with the engine. There is a malfunction is in either the electrical system, PTO clutch or one of the safety features somewhere. Check all of the belts first for wear or breakage, then if they're OK, you probably need a small engine mechanic, but it doesn't sound really serious.
Jul 02, 2017 | Kohler Electrical Supplies
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
John deere 111 dies when go to move it
I just got done with real similar prob my at first would start not rev up very well could drive it fine try to engage pto it die i checked everything carb back fire prevention was good cleaned carb seat switch checked out fine ignition switch had little corrosion changed it nope then it started to die after i started it and let out on foot pedal thought that was it checked with wires hooked up still get different readings each time unhooked switch it checked out fine then the seat switch would give me different readings on meter took it off test again fine was ready to have a fire sale on this pos i started to go through every electric con. Clean and make sure contact were good noticed a small crack on ignition switch female plug then found same on pto female plug got new plugs put wires in fixed everything
Jul 02, 2013 | Garden
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Oct 13, 2009 | Garden
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
148 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
