Question about Kenmore 82822 Electric Dryer
Duet dryer drum is loose, felt seal on back of drum does not sit tight. Can see light which it should be tight. Problem was created when someone helped me to raise it on top of the washer and they let it slip. It did not fall down but it was trouble raising it on top of the duet washer. My washroom is small so I have to have it stacked. I have taken it apart and put it back together. It is loose,.
    Sergeant:
  • 313 Answers
Sounds like your dryer tub got bent
Posted on Oct 17, 2013
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Can not get it apart!!!!!!!!!!!!
Here's the repair manual.
Let me know, OK? At the very least, you can rate this solution, right?
SG
Posted on Apr 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I need help putting my dryer back together
Here is a couple of websites that shows the breakdown and parts of dryers, maybe they will have your model to help show where the two springs go.
http://www.appliancepartspros.com/index.aspx
You could also try this website.
http://www.partselect.com/
Good luck,
I hope this helps
Posted on Oct 06, 2009
  • 70 Answers
SOURCE: I have a stackable washer and dryer. Both have
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Posted on Jun 23, 2010
Felt seal on back part of drum whirlpool
Felt seal and glue
What I would do is take the dryer apart and remove the old drum seal. Get as much of the old glue off there and install new felt. I tuned upa dryer built like yours not long ago and took some photos.
Roper dryer tuneup
Nov 02, 2011 | Whirlpool WED5300S Electric Dryer
Have whirpool Duet dryer....leaves brown streaks just like everyone else's. What do I do to fix the problem? Can I do it or am I going to have to pay someone? Company should have a FREE kit to repair....it...
Hello there:
If your clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer eats my clothes by twisting them up between the drum and door. is there an update to fix this?
the front of the drum rides on a felt pad. as the pad wears down it creates a gap for the clothes to get caught in. you just need to replace this felt. sometimes called front bearing sometimes called felt seal.
Jun 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool duet dryer mod gew922507pw1 lleaving brown streak on cothes
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes getting stuck in front of dryer the model wasn't listed below mode is LDE8404ACE
If your clothes are getting stuck in the front of the dryer, it could mean more than one thing.
Your front felt seal is faulty, broken, or out of position.
After years of use, the front felt seal on the dryers break down,come loose, or become faulty. It is also sometimes caused by wear in the drum rollers, and this causes the felt seal to become worn.
You will need to replace the front felt seal and possibly the drum rollers.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum, felt seal and belt. It is a good time to check and replace the felt seal. You could stop there but I recommend that you do the following:
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they are worn or have flat spots on them replace them.
If the drum rollers don't have flat spots on them and is not worn, then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 14, 2009 | Maytag PYE2300AY Electric Dryer
Duet dryer drum rubbing
There is a felt seal on the drum that might be wore and will need to be replaced.(Note if not replaced it will ware your drum and ruin it.
It is something you will probably want a repair man to check out for you.
Oct 21, 2009 | Whirlpool GEW9250 Electric Dryer
Hi, when dryer is running it is noisy. It is level, all 4 legs are tight and have rubber feet attached. Noise continues after load is leveled and when only 1 or 2 small items are being dried. Appears to be...
You need to replace the 2 rear drum roller wheels and probably the rear drum felt seal. While you have it torn down inspect the front drum glides for wear.
This dryer is worth repairing.
Aug 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 82822 Electric Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
