Question about Eiki LC-X1100 Multimedia Projector
Eiki LC X1100 - the unit is loosing all power [no standby leds] when switching on after being off for 5 minutes or more. I've found that if power is disconnected and Reset switch is engaged it will come back on after power is restored. Any ideas ? Tim
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
In primary power-supply circuit there are 2 smd capicitors,1uF and 2.2uF, replace them both by standard radial 105 C electrolytic, also replace the 220uF capacitor that is located beside these 2.
Posted on Apr 17, 2014
Benimur
  • 6966 Answers
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Posted on Jul 31, 2007
SOURCE: the projector switching off after 30 seconds
check the following :
1.does the lamp glow
2.do u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
Posted on Feb 08, 2009
projdoc
  • 2237 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
projdoc
  • 2237 Answers
SOURCE: Eiki LC-X1100 Powers "off" after 10-15 minutes
even if the filters are clean, you will still need to blow the dust out of it with canned air. may be overheating. otherwise, sorry to say, it is the ballast.
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
Eiki lc x1100 multimedia projector lyrics are "shadowed" with multicolors
screen ,the color is ghost,
LCD panel is broken.you need a new one USD120
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 19, 2013 | Eiki LC-X1100 Multimedia Projector
Can get any power on on my eiki lcx 1100 projector
Thermal fuse, located under the lamp might be activated, open lampdoor and push carefully the little black pin. If it gives a click it was
activated due overheating. If not, replace 1uF, 2.2. uF and 220 uF capacitors in primary part of the power supply, it takes some work to get the pcb out of this model !!
Jan 23, 2013 | Eiki LC-X1100 Multimedia Projector
Eiki LC-SD10 Projector will not power on.
any led on ? if no, check thermal switch near lamp house or dried out capacitors in power supply
Aug 20, 2011 | Eiki LC-SD10 Projector Multimedia...
My Eiki lc-x1100 is not displaying very bright. I bought is used from a university and it only has about 900 hrs. on the present bulb. Is there something else that would make it dim? Don't want to...
i would check the physicality of the lamp. once you've removed it, look around the filament of the lamp, and if you notice any dark corrosion build around it, then that's what's causing the dim image. if it looks clean and clear, it might be one of the mirrors within the projector's optical engine.
May 24, 2011 | Eiki LC-X1100 Multimedia Projector
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try www.projectordoctor.com
Nov 10, 2009 | Eiki LC-X1100 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
Feb 11, 2009 | Eiki LC-X1100 Multimedia Projector
Eiki LC-X1100 Multimedia Projector Logo
96 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
