Question about HP FS492AWABA - Compaq dc7900 Convertible Minitower PC Desktop
I have several dc7900 not turning on. The mainboard and ethernet port is flashing amber on one and two just the mainboard is solid amber
  • Greg Just Oct 16, 2013
    The tech who has previously repaired the desktops for me said he had replaced capacitors as they had blown, I'm wondering what the difference is showing with the flashing amber lights as opposed to solid amber...
    also how do you tell when a capacitor is blown other than the top of the capacitor being raised which I cannot see on any of the motherboards...
    Master:
  • 680 Answers
Remove the power plug from the back of the computer. Take a small screw driver and cross the two vertical leads then cross the left lead to the ground post then do the same with the right one.Plug it back in and see if it turns on then if not it could be your power supply caused by a power surge. Is my guess.
Terry
Posted on Oct 17, 2013
Testimonial: "It is almost certainly caused by a power surge - but it's not the power supply as I have 8 of these dc7900's and have tested it on a known good power supply. Problem is the capacitors which I am about to replace, but wanted to know what the difference in the two symptoms was...."
What do the different color leds mean on the NVG589 on the ethernet ports
From the manufacturer's manual (page 92):
Ethernet 1,2 3,4:
  • Orange/Amber:when a Gigabit Ethernet device is connected to each port.
  • Green: when 10/100 Ethernet device is connected.
  • Flash for Ethernet traffic passing.
http://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/26009/1/Motorola%20NVG589%20VDSL2%20Gateway.pdf
Dec 12, 2014 | Computers & Internet
How reset bios dc7900 CM
You can remove CMOS battery and turn on your PC, by removing the battery from the mainboard you restart BIOS and rest of the boot features before windows loading.
Aug 18, 2014 | HP FS492AWABA - Compaq dc7900 Convertible...
Sony Bravia KDL-60EX700 BAL Board / Flashing Green Amber
It sounds to be a firmware trouble. Will be best to contact the authorized service center for Sony, rather than trying to do it by yourself, as it is a very skilled work, need both concentration and previous experience. google.com/+GopakumarGopalan
Nov 24, 2013 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
I have a Netgear DGN1000 Modem Router, and I currently have two PC connected via Ethernet cables. For one, the light is solid green, whereas the light for my laptop is flashing orange/red. I can still surf...
amber light means your only getting 10Mb speed. Your ethernet port could be going bad on the laptop. Go to control panel > Network Settings > right click Your Network (LAN) adapter, properties, click configure, advanced tab and make sure your link speed is set to "auto negotiate" or "auto detect"
Apr 02, 2012 | Computers & Internet
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Amber lights on a Cisco switch.
It sounds like you have loops in your topology. Loops will cause the LAN to crawl.
Amber, on a Cisco switch port means that a port has been blocked either as a security violation (if mac-address security is being used) or by spanning-tree protocol which shuts down ports involved in a network loop.
Check all your wiring carefully...especially the fiber-to-ethernet converters. If anybody has a hub or switch under their desk make sure they do not have two ports from that device patched into two ports in your cisco switch.
From Cisco catalyst 3500 user guide:
Solid amber
Port is not forwarding. Port was disabled by management or an address violation or blocked by Spanning-Tree Protocol (STP).
Note After a port is reconfigured, the port status LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
Nov 02, 2009 | Ortronics (MC62503)
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
HP FS492AWABA - Compaq dc7900 Convertible Minitower PC Desktop Logo
87 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
