Question about Homelite Pump Seal Kit Water Pump Part A-48377 for Old Pumps
Need a seal for the water pump - Homelite Pump Seal Kit Water Pump Part A-48377 for Old Pumps
    Sergeant:
  • 216 Answers
Here is a link to your parts.
Overhaul kit
Posted on Oct 20, 2013
I have a antifreeze leak on a 2003 ford sports trac
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e4058#hd1-1-1 Hi Donna,here's a link to the water pump diagram,is the mating surface that the gasket goes on clean and not badly scraped up from removing gasket,the pump itself is aluminum and could be warped and not sealing good causing it to leak,maybe you need a new water pump,hose on that side isn't leaking?
Oct 12, 2012 | Ford Vehicle Parts & Accessories
2003 honda shadow 750 ace water pump gasket leaking. Can I replace the gasket only?
There is a round o-ring that seals the water pump to the motor (oil seal). Then there is a shaped cover o-ring that seals anti-freeze into the pump. The cover o-ring is also replaceable. If your pump has coolant leaking it is probably coming from a small weep hole in the bottom of the pump. Check where the leak is carefully, my guess is that the water pump seal is bad and you actually need to replace the water pump assembly. To see a break down of the pump look here.
http://www.bikebandit.com/houseofmotorcycles/2002-honda-vt750cda-shadow-ace-deluxe-black/o/m2894#sch94027
Mar 17, 2011 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
I have an oil leak from a drain hole in front of engine.what could be the problem?
If the oil plug bolt is leaking you need a new aluminum sealing washer. There are no oil weep holes in the front of the motor. Is it the weep hole under the water pump? You probably have a bad water pump seal or a bad oil seal on the water pump shaft. Buy a new water pump and the K&L water pump gasket kit. The K&L gasket kit comes with all the gaskets, seals, and washers necessary to do the water pump replacement for a fraction of the cost of the OEM Honda individual gaskets, seals, and washers.
Jan 30, 2011 | 1985 Honda GL 1200 Aspencade Gold Wing
Milky oil on my wr450f 2004
your water pump seal and oil seal have failed on the water pump shaft. Replace both seals noting which way the seals face. replace the water pump shaft if it is scored. Chaz- Moto DC
Jan 20, 2010 | 2004 Yamaha WR 450 F
I have antifreeze leeking out a pin hole under the water pump
It is very likely the water pump seal. It is always a good idea to replace the bearing while you have it opened up.
Jan 13, 2010 | 2002 Honda CRF 450 R
Lossing water out of small hole on under side of motor ? Normal or not
Not, sounds like a seal vent for the water pump, shouldn't leak.
Jan 07, 2010 | 2005 Honda CRF 450 R
Why is there a water leak coming from the water pump?
i would say you answered your own question, if there is water leaking from the water pump i would say the water pump is leaking and it needs to be replced,either the bearing is bad and its leaking out the shaft,or the seal is bad and its leaking outta there either way you need a new water pump,check the belt for wear when you replace it,,
Oct 07, 2009 | 1998 Dodge Caravan
I have a leak in the water pump on my Kubota F2400 and also a oil/hydraulic fluid leak somewhere underneath the engine. I need to repair them. Help.
your rear seal (oil) pump and mybe your engine seal both are out. do you have water in the pump oil? if so your water seals are out too. need to get A comlete seal kit for the pump.
Oct 05, 2009 | Garden
Water pump seal leaking - engine temp normal
HI. you will need to replace the water pump asap. once the seal is breached its a done deal. Its only a matter of time when the seal completely fails, causing a very serious over heating situation that will damage this fragile engine.
May 22, 2009 | 1998 Cadillac Eldorado
Homelite Pump Seal Kit Water Pump Part A-48377 for Old Pumps Logo
Top Homelite Plumbing Experts
richie46
Gil Shultz
Robert Dean
Robert Dean
Level 1 Expert
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
