Question about LG Televison & Video
LG 47LE5500 - Has a mind of it's own Flips through menu options without touching remote (likes going into input functions, but does go into anything.) Hearing popping/beeping noises from back of unit. Any assistance, I would be greatful
5 Suggested Answers
  • 2318 Answers
SOURCE: Display continueuly changes
Unplug your device for about 30 minutes to let the circuitry reset itself.
If it works normally after that, it means a hardware part(s) is overheating inside, more likely a power supply is starting to fail and does not provide the proper voltages for the microprocessor.
Posted on Jul 04, 2008
maatmartin7
  • 1210 Answers
SOURCE: volume goes down to 0 and the menu goes on and off.
A bad connection on the small signal board may be the problem! Have a Tech check this connection, it may be to tight due to the heat shrink tube. Have them peel it back to reduce the strain! Should work then!
Posted on Apr 14, 2010
SOURCE: TV has a mind of it's own. I turn it off & it
It might be something as simple as stuck buttons on the TV. If you open the back, try disconnecting the lead that goes there. Maybe work? You'll be forced to use the remote, of course.
Posted on Oct 31, 2010
wolfungarman
  • 148 Answers
SOURCE: Philips Customer Service
I'm just reading http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=37PF7320A/37&slg=en&scy=US page where there is Documents to read or download, Software and Drivers like Firmware and its Read Me file on HOW TO as well as FAQ's mentioning something I suspect you're experiencing with yours.
I think this is your best place to start, good luck.
Posted on May 15, 2013
How can i hook up a dvd player to a Sylvain tv with no remote
Ok the brand of the tv is not as relevant as the particular model number as each set varies. generically speaking without having to ask you for more information, some tv set allow you to access auxiliary inputs without a remote by pressing a combination of buttons or repeatedly pressing the channel up or down button until the inputs are cycled. A lot of set also allow you to navigate through inputs by the menu, a menu is often accessible by buttons on the set. If none of these options are avaliable try contacting your tv manufactor and asking how to navigate the inputs Witout the remote, which keep in mind is highly possible that you may not be able to do so. Consider replacing the remote with a universal remote.
good luck and thanks
Questions? Just ask! Mr.Mike
Nov 17, 2015 | Televison & Video
Jul 04, 2008 | Dell W2300 23 in. HD-Ready LCD Television
I can't seem to change function from DVDs/usb to aux or radio function on my lg home theater fb162. With or without the remote present.please assist
Whether the remote, or using any buttons on the unit, those inputs go into a microprocessor(computer within your unit). There can be other issues, but that is the most likely.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Aug 09, 2015 | LG Audio Players & Recorders
How do i hook it up to my computer without a remote
"How do I hook up my computer without a remote?"
Two possibilities come to mind:
1. With a VGA (15 pin), HDMI, or DVI connected computer there should be a keyboard key combination (typically a Function button (Fn ) and one of the F1 thru F12 keys) that will activate the option for switching the video signal to the external monitor/TV, or in the case of a laptop, viewing the image on both screens. The TV's "INPUT" button, if there is one, will need to be pushed several times to cycle through the available input signals until the computer video signal input is seen.
2, Alternately, if there is no "INPUT" button, it may be possible to purchase an inexpensive universal remote (ones seen even at a local $1 Store) in able to access the TV menu. The remote will have programming instructions and codes for most major TV brands, and an Internet search, or the TV manufacturer, should provide for additional codes for your specific TV model if necessary.
Kindly post a reply if either of these options do work for you.
May 27, 2013 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have programmed my remote to an older JVC television. everything works, but i cannot change the input from the remote. I have a ps3 hooked to the tv. anytime i want to play my ps3 i have to manually...
If the tv has an input button on the side it should let you scroll through all the inputs without having to go through the menu. Hope this helps.
May 24, 2011 | Televison & Video
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
TV has a mind of it's own. I turn it off & it turns itself back on. It pulls up the input menu without me hitting the input button. Then it switches between the input options without me hitting...
U have some skills like take things aparts and putting it back together again?Yes?The tv Tuner signal board have problems,might even be the CPU itself have some kind of shorts.The Tuner signal board,that the board,where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Oct 28, 2010 | LG 47LG50 47 in. LCD HDTV
Lg will not respond to remote.
Does it work without remote OK.
You have to go to service mode menu and adjust. Only service center can help you.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Change HD settings on lg plasma tv without remote
u need tv remote, with that u can go to the options for ur tv and enable the hdmi allowing ur ps3 to come onto ur tv.
Dec 31, 2008 | LG 50PX1D 50 in. Plasma Television
TV Remote
hi,
I posted a fix on one other thread, you can get a universal remote to acces that function, newer directv remotes have the menu function
J
Jun 19, 2008 | Disney 13" TV
Televison & Video Logo
Computer Repairing
Computer Repairing
