Question about Migali Compact Work Top Refrigerator 72inL
My american range convection oven makes a buzzing noise.
When the oven is on, there is a constant buzzing noise until the oven cools off. it is not the convection fan!
I would call a repairman to check for a loose wire . buzzing could possibly start a fire eventually
May 23, 2016 | GE Profile PS905DPBB 30" Slide-in Electric...
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
I have a convection Microwave , when you close the door it makes a buzzing noise. what would cause this?
You don't note the make or age, but most of the convection/microwave ovens are actually made by Sharp. I have one, and there are 4 microswitches that monitor the door and door latch. These go bad and need to be replaced. You can have a service technician do it, or it's not hard to remove them and replace them yourself.
Oct 13, 2014 | Microwave Ovens
I have an american range gas convection oven i think lightning may have struck them but they still run but the gas will not come on the igniter just keeps ticking and no gas
there posible pilot burner is clogged, you may want take off the gas pilot tube and make a quick turn on to see gas is come out from pilot tube or disconnect from gas valve pilot connector...have fun....
Sep 23, 2011 | American Range Ovens
Kitchen wall oven there is a buzzing sound when in the convection bake cycle
You don't tell the age of the oven... but the convection fan motor bearing is stressed by the heat of the oven.... and over time can cause all sorts of noises.
You may want to place a small amount of WD-40 on the convection fan motor bearing... just to confirm it as the problem/
Best to replace the motor if it is the problem..
-Jim
Oct 17, 2009 | Ovens
Bad fan noise from convection oven
THE ROD THAT HOLDS THE FAN BLADE IN PLACE IS WARPED BENT OR LOSE SOUNDS LIKE YOU BOUGHT IT THAT WAY EASY FIX! ORDER PART AND DO YOURSELF
Nov 16, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Oct 25, 2008 | KitchenAid KEMC377K Convection / Microwave...
Convection Oven Fan Failure
if the fan is cheaper you can replace it your self if it was making a noise id say thats where the trouble was
Jan 30, 2008 | KitchenAid KERA205P Electric Kitchen Range
Viking Micro noise
The noise is probably from the high-voltage transformer. When it is overloaded, the excess magnetic field it produces vibrates its wire coils. Odd that it only happens for a brief time. It is either defective itself (in which case it may go a long time) or it is getting overloaded by the magnatron/capacitor/diode on its output (in which case it will get worse shortly)
Hope Ya Fix it
Jan 08, 2008 | Microwave Ovens
Migali Compact Work Top Refrigerator 72inL Logo
24 people viewed this question
Top Migali Refrigerators Experts
Ilia Bichin
ray gallant
Tom Chichester
Are you a Migali Refrigerator Expert? Answer questions, earn points and help others
