Question about Migali Compact Work Top Refrigerator WCutting Board 465inL
I can't figure out how to clean the coil on my migali work top freezer
Why is my top freezer partially cooling
clean your coils in the back of the fridge or look under neath to clean them- a vacuum with the long skinny nozzle will work or Home Depot and Lowes sell a Coil cleaning brush about $12
Oct 25, 2016 | Refrigerators
Why my refrigerator and freezer is not cooling
Are you speaking about fan beside compressor. Make sure condensor is clen of lint
May 18, 2014 | Migali Imperial Series Aluminum Reach In...
Excessive water at bottom of inside of refrigerator box. Just cleaned coils on bottom. Was that my problem?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool ET8FTEXV Top Freezer...
Where to clean coils
this freezer has what is called a hot wall condenser so there are no coils for you to clean. make sure that you dont put anything right on top or real close to the sides of the unit and you will be ok. thx for using fixya peyton
Feb 06, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Need to clean out the defrost drain tube on our Kenmore refrige
remove the back freezer panel and the drain is below the coils in the drain trougth. use hot water to remove the ice to get to the drain inlet.
Dec 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Migali Compact Work Top Refrigerator WCutting Board 465inL Logo
21 people viewed this question
Top Migali Refrigerators Experts
Ilia Bichin
ray gallant
Tom Chichester
Are you a Migali Refrigerator Expert? Answer questions, earn points and help others
