Question about Sewing Machines
Pfaff 2027 stops sewing. error shows WD - Sewing Machines
3 Suggested Answers
  • 255 Answers
SOURCE: Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
Posted on Mar 15, 2010
danicarby
SOURCE: My Pfaff 1229 doesn't stop sewing when I let off the pedal??
I had this same problem with my Pfaff 1222E. It happened after I dropped the foot pedal pretty ******* the floor. Luckily I had another 1222E and opened up both foot pedals to compare and sure enough there was a piece in there that shifted and was toughing what is was supposed to so I just had to move it back over and it worked perfectly!
Posted on Nov 14, 2012
How to replace power foot pedal cord pfaff 2027 sewing machine
under the anti-slip strip there are screws to be eased off and the pivoting shaft can be pushed out. The difficult task is to re-assemble - the contact wiper is springy and is hard to keep away from the small resistor strip when closing the top. Not recommended for DIY.
Oct 27, 2015 | PfaFF Sewing Machines
Pfaff 1475 manual
Not sure if your model is the creative 1475. The closest I can find at a service website of Pfaff is 1473. Check if this is similar to your model and it shows where the balance wheel goes.
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
Also see this Youtube video showing how to insert the bobbin after threading.
Pfaff Creative 1473 CD sewing machine in action
otherwise you will have to buy service manual for eBay
PFAFF CREATIVE 1475CD Sewing Machine Service Manual
Aug 12, 2014 | PfaFF Sewing Machines
Buttonhole feature
try changing the needle
make sure the button hole lever is pulled down, it should be on the left
hand side of the needle, if your machine has one
it's also possible that the machine needs to be checked to see if
there is something wrong with a gear or just needs some type of
adjust inside of the machine
Sep 04, 2012 | PfaFF Sewing Machines
My Pfaff Classic Style Quilt 2027 is getting large thread snarls on the underside of the fabric.
Top tension problems. Tighten the tension.. and make sure you hold the threads when starting a seam.
Sep 02, 2012 | PfaFF Sewing Machines
Random error messages
It is a signal that one of the computer boards may be going bad. It would be best to take your machine to an authorized Pfaff technician to diagnose. While your neighborhood sewing machine repair person may be good, they may not be trained specifically to deal with Pfaff computer issues.
At this point, you can continue sewing (over-riding the message) but eventually it will likely worsen.
You can locate your nearest dealer through Pfaff's Dealer Locator. If you do not have or prefer to not use your local dealer, please respond to this with a request for a referral and we'll do our best to find a good tech near you.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 25, 2008 | PfaFF Creative 7570
Pfaff 7550 display gone out
I have a Pfaff Expresion 2026 which started doing strange things.
First the display went out, and it showed the error message "WD". Then it would sew briefly with a different stitch length and also in reverse, before stopping altogether.
I spoke to my dealer about this, and she had come across the same problem once before, which was rectified by changing the light bulb. Incidentally, the light was still working.
I changed my light bulb and all is now well. Hope it works for you, all the best.
Sep 11, 2008 | Sewing Machines
No display
I have a Pfaff Expression which went the same way, but showed the error message "WD".
My dealer advised me to change the light bulb, which I've done, and since then its been fine.
Hope this works for your too.
All the best.
Aug 31, 2008 | PfaFF Quilt & Craft Pro 7530
Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Apr 26, 2008 | Sewing Machines
Sewing Machines Logo
163 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
